There are 2 servers I'm administrator on, and both of them are running ULX, their banlists are not linked in any way, but they share a similar problem, whenever you try to open the Ban Menu or try to ban someone, the server crashes. Before this occurred, both servers had only about 7 bans. On one server, we checked the Ban file, and it was 65 MB. I found this to be similar to the problem posted in
This Thread. The file size is about 64 MB, and confirms that there are only 8 bans, but on the last ban under the "name" field, there is about 50k + froward slashes. In the code below is the latest ban, with about 50000 lines of "/" removed:
"STEAM_0:1:15065817"
"admin" "=NYS=BillyHasACookie(STEAM_0:0:19871114)"
"unban" "0"
"time" "1227993495"
"name" "/V) /-) G l//////////////////////////////// ... and so on ... ////////l l_l §"
"reason" ""
You can download the banlist at
http://notyouraccountservers.com/test2.zip. This is not Compressed, we just changed the extension of the file to .zip to make it so we can download it. Just change the extension of the file to a txt when you've finished downloading the file.
I don't have the last server's banlist, but the problem may be similar.
Thanks in advance for any support
