Author Topic: Few Issues On A Server  (Read 3939 times)
Offline gega2202
« on: January 11, 2009, 05:53:09 am »
 I'm having some trouble using certain ULX functions. On my public server, I can't add a user to a group without there being a 60 second lag and then the server is back, props intact. The user will be added until the next server restart, in which they'll go back to their old rank.
 We're also having trouble with the ban menu; it's been crashing JUST the person who tries to open it ever since the other owner of the server banned a person with a changing name script. Any tips on how to repair? (We've tried renaming the current list so a new one gets written, didn't work out too well.)
Re: Few Issues On A Server
« Reply #1 on: January 11, 2009, 10:34:29 am »
It sounds as though files on your public server host is having issues more so than ULX, but ULX is just a piece of the issue.
Both functions your having trouble with include ULX reading or writing to files on the server.
If they're both corrupted for any reason, they could cause sporadic odd issues.
Re: adding user.
While players having the trouble are connected to your server, and you at the console, run "ulx debuginfo"
It will create a file called gmod\data\ulx\debugdump.txt on the server. Attach that file here using the 'additional options' menu at lower left of the post window.
Depending on what's seen there, we may be able to proceed.
Re: adding bans/using its menu.
In our latest release version (that is, not SVN), we know of an issue that can crash servers when the ulx ban menu is opened due to corruption in the temp ban file we use. (We believe we've corrected it in SVN beta code)
Though I've never seen it crash an individual, I guess it could happen.
I recommend moving your gmod/data/ULib/bans.txt file. This will not affect any permanently banned player, only those that have been temporarily banned.
Once moved or deleted, restart the server entirely (not just a map change)
Let us know if that helped.
Offline gega2202
« Reply #2 on: January 15, 2009, 12:47:28 pm »
Thanks JamminR! Luckily our other owner was able to discover the same issues (for the same reasons) on his own at the same time I read this. Wierd.
