Author Topic: AutoPromote  (Read 186526 times)
Offline HOLOGRAPHICpizza
    • GmodPlanet.com
AutoPromote
« on: January 14, 2009, 07:51:18 pm »
AutoPromote is a lightweight UTime-integrated alternative to other promotion systems such as APromotion.
UTime and ULX are requred for this addon to operate.
To install, extract the AutoPromote folder to C:\Program Files\Steam\steamapps\<username>\garrysmod\garrysmod\addons\
Configuration options are at the top of AutoPromote/lua/ulx/modules/AutoPromote.lua
This addon is realeased under the MIT license, which gives you the right to use, distribute, and modify as long as you give me credit.
Version 3.1 includes a variety of bugfixes and improvements by me, Major_Pain, and Smithy.
« Last Edit: December 30, 2009, 03:28:13 pm by HOLOGRAPHICpizza »
Quote from: Jeremy S. Anderson
There are two major products that came out of Berkeley: LSD and UNIX. We don't believe this to be a coincidence.
Open Source • Net Neutrality • Ubuntu • Firefox • Sumatra PDF
Re: AutoPromote
« Reply #1 on: January 14, 2009, 07:55:20 pm »
Very cool work! Interesting that you chose to build it off UTime, but it does seem like the two go hand-in-hand. :)
Offline ASpeidell
Re: AutoPromote
« Reply #2 on: January 15, 2009, 06:01:44 pm »
it won't promote my users after they have passed the three hours mark, what am i doing wrong?
if not SERVER then return end
--AutoPromote 1.0
--Automaticly promotes players to different groups based on UTime.
--By HOLOGRAPHICpizza. Released under the MIT license.
local promoteGroups = {
--   Groups must be listed in decending order.
--   ["hours"] = "group",
        ["72"] = "member",
        ["48"] = "vip",
        ["24"] = "highlyrespected",
   ["12"] = "respected",
   ["6"] = "regular",
   ["3"] = "builder",
        ["0"] = "user",
local excludeGroups = {
   "owner",
   "admin",
   "superadmin",
    • GmodPlanet.com
Re: AutoPromote
« Reply #3 on: January 16, 2009, 01:10:10 pm »
Make sure you have UTime and ULX installed and properly configured.
Make sure the group you want to promote to actually exists and it is possible to promote users to the group manualy.
Make sure you have completely restarted the server after installing the addon.
Make sure the user is not in an excluded group.
Remember that the script only checks hours when the player dies, and users are not promoted as soon as they hit the hour mark, they need to die first.
Try changing the config section to look like this:
["72"] = "member",
["48"] = "vip",
["6"] = "regular",
["3"] = "builder"
Note the lack of the users group and the lack of a comma after the last entry.
Also, please post any error messages you get.
« Last Edit: January 16, 2009, 02:01:00 pm by HOLOGRAPHICpizza »
Offline ASpeidell
Re: AutoPromote
« Reply #4 on: January 17, 2009, 04:56:33 pm »
That seemed to fix it...thanks, dude
you da man
« Last Edit: January 17, 2009, 07:36:34 pm by ASpeidell »
Re: AutoPromote
« Reply #5 on: January 18, 2009, 08:06:54 pm »
Congrats on the release!
Something I'd like to see is a simple gui that shows remaining time until next promotion, and what group you will be promoted to :D
Another not, if you'd be interested, I'd like to see this script merged into APromotion as an addon that will promote with/without UTime.
Would only take me about five minutes to merge them if you are interested, you will get full credit for your work of course. I make this offer,
because you've done what I've planned on, but not had time to do.
Feelings wont be hurt if you choose not to, just trying to make things simple. One addon multiple solutions :D
EDIT:
    - You can choose name :D
Offline Cephalexin
Re: AutoPromote
« Reply #6 on: January 27, 2009, 01:55:46 am »
if you accepted the offer that would be cool :D
    • GmodPlanet.com
Re: AutoPromote
« Reply #7 on: January 28, 2009, 12:02:05 pm »
Hey, this is why I chose an open-source license. You can go ahead and merge it into APromotion, just give me credit. I'm still going to keep AutoPromote up for people who know for sure they only want it with UTime and they want it to be as lightweight as possible, like me. But this is why I chose the MIT license. You are free to do whatever the heck you want with the code, just make sure I get credit.  :)
« Last Edit: January 28, 2009, 12:11:30 pm by HOLOGRAPHICpizza »
Re: AutoPromote
« Reply #8 on: January 28, 2009, 08:42:12 pm »
Hey, this is why I chose an open-source license.<clip>
* JamminR claps.
I've used code from others before, then basically ended up totally rewriting the code to do the same function but more efficiently.
I still put in comments 'loosely based on idea by <author>'
I love collaboration and learning from others.
Offline XbabyX
Re: AutoPromote
« Reply #9 on: February 15, 2009, 10:16:56 am »
Hey guys i got some problems too, i hope i can get some help here, its just not working.
--AutoPromote 1.0
["100"] = "msergeant",
["50"] = "sergeant",
["25"] = "1337",
["15"] = "respected",
        ["10"] = "VIP",
["5"] = "private",
["2"] = "builder"
"member",
"moderator",
"admin",
"superadmin"
--DO NOT EDIT BELOW THIS LINE UNLESS YOU KNOW WHAT YOU ARE DOING--
--Checks if they are ready to be promoted.
function deathCheck(ply)
if not excludeCheck(ply) then
local newGroup = promoteCheck(ply)
promote(ply, newGroup)
hook.Add( "PlayerDeath", "deathCheck", deathCheck )
--Check if they are in an excluded group.
function excludeCheck(ply)
local excluded = false
for k, v in ipairs(excludeGroups) do
if ply:IsUserGroup(v) then
excluded = true
return excluded
--Check what group they fall in.
function promoteCheck(ply)
local hours = math.floor((ply:GetUTime() + CurTime() - ply:GetUTimeStart())/60/60)
local newGroup = "user"
for k, v in pairs(promoteGroups) do
if hours >= tonumber(k) then
newGroup = v
return newGroup
--Promote the player to the group.
function promote(ply, newGroup)
if not ply:IsUserGroup(newGroup) then --Make sure we don't promote them tho their current group.
game.ConsoleCommand("ulx adduser " ..string.format("%q", ply:Nick() ).. " " ..string.format("%q", newGroup).. " \n")
Is that correct?
    • GmodPlanet.com
Re: AutoPromote
« Reply #10 on: February 15, 2009, 10:55:18 am »
What specific problem are you having? The config looks good to me...
Post any error messages you encounter.
Offline XbabyX
Re: AutoPromote
« Reply #11 on: February 15, 2009, 11:09:51 am »
lol my fault, he didnt get promoted because he was alive. He had to die. But thanks anyway
Offline DiscoBiscuit
    • DiscoBuild
Re: AutoPromote
« Reply #12 on: February 22, 2009, 12:25:35 pm »
It won't promote players for my server either...
I have ULIB and ULX installed properly, and UTime, and I made each group in ULIB's groups.txt but it still won't promote them, even after death. Here's the code:
--AutoPromote 1.0
["24"] = "senior"
["15"] = "legendary"
["12"] = "awesome"
["10"] = "respected"
["8"] = "1337",
["6"] = "pro",
["4"] = "builder",
["1"] = "experienced"
"moderator",
"vip",
"admin",
"superadmin"
excluded = true
return excluded
newGroup = v
return newGroup
    • GmodPlanet.com
Re: AutoPromote
« Reply #13 on: February 22, 2009, 12:47:02 pm »
Sorry, I don't know what to tell you, the code looks good...
Make sure that you can promote users to the group manually.
Re: AutoPromote
« Reply #14 on: February 22, 2009, 04:39:49 pm »
Also, make sure the player has died. Suicide works, fun "slay" initiation would work too. :)
Don't know if HolographicPizza has added any other check events, but they specifically mention death in first post.
