Author Topic: keepragdolls command  (Read 25349 times)
Offline Dv2236
    • MyGamingVoid
« on: January 22, 2009, 11:49:10 am »
I know this is not a problem to have to do with Ulysses team! but I'm just looking for some help wear ever I can find it, This options has been pissing me off for months.
first off I will tell you all I have no addons installed at all for this test and I installed Gmod fresh and clean.
I also know about the NPC menu button for keep corpses!
Now the thing that gets me is the command ai_keepragdolls/ that button in npc menu works in singleplayer! but not in multiplayer?
any ideas?
Re: keepragdolls command
« Reply #1 on: January 22, 2009, 02:29:11 pm »
Tried setting it in your server's server.cfg?
Offline Dv2236
    • MyGamingVoid
« Reply #2 on: January 22, 2009, 02:37:45 pm »
Yes I have. sadly still nogo :-\
Something I also found kinda funny, in singleplayer you jump alittle bit higher than in MP.
 I have tested both of this in a dedicated server and hosting with the client BTW.
« Reply #3 on: January 22, 2009, 08:41:59 pm »
Google is your friend.
I searched for the term "ai_keepragdolls".
It found your post on facepunch within the top 5, in which someone said they thought Ragdolls were client side.
Makes sense. Ragdolls could lag a server. It's why the limit for them not be too high.
Now, on page 2 of the search results, I found code for something called Z-day project.
http://zday.googlecode.com/svn-history/r492/trunk/gamemode/init.lua
WITHIN that are TWO commands, including the ai_keepragdolls.
The second will probably help out in keeping ragdolls on the server.
"ai_keepragdolls 1"
"ai_force_serverside_ragdoll 1"
If that doesn't work, no idea what else to suggest at this point.
Good luck, and if it works, you're welcome.
Offline Dv2236
    • MyGamingVoid
« Reply #4 on: January 23, 2009, 12:01:33 pm »
sorry for the delay on the reply, but I have tried that command and feeling kinda dumb that I did not see it when I did "find ragdoll" in the command menu.
sadly to say though it did not work. I know it use to work a long long time ago, but for what ever reason garry's team I guess just dont want anyone to use it in MP!
also i only tested that "ai_force_serverside_ragdoll 1" command in client hosted MP, I'm having majer hard core problems with my domain/DNS/webhost/webmail so just did not have the time.
« Last Edit: January 23, 2009, 12:03:17 pm by Dv2236 »
