Author Topic: Removing admin without them been on the server.  (Read 5104 times)
Offline wilkisam
« on: January 31, 2009, 12:53:17 pm »
Hi, i was wondering how to revoke a person of admin without been on the server through the server console?
Regards
SW
Re: Removing admin without them been on the server.
« Reply #1 on: January 31, 2009, 05:22:23 pm »
Hi.
Please see our FAQs section "How do I remove a user?" - method 2
If you've set them using the standard Garry users file method, you'll need to remove them from gmod\settings\users.txt too.
« Reply #2 on: February 01, 2009, 09:09:11 am »
Keep in mind Method 1 of the link JamminR posted requires the admin to be on the server at the time.
There is no Console way to remove a user from the ULX generated users file while they are not in the game.
On a further note... you can remove them from teh file manually (method 2 from the link) however since the file loads only once per map change, if the admin should happen to join after you remove them, but before the map changes/server restarts they will still have their accesses as an admin.
