Author Topic: Wire Limits  (Read 13156 times)
Offline jlj1
Wire Limits
« on: February 01, 2009, 11:39:04 am »
Works in the same way as the other limits with a slider between 1-100 (depending on the component)
Thanks in-advance
Re: Wire Limits
« Reply #1 on: February 01, 2009, 11:52:12 am »
I believe someone already made this somewhere on the forums...
Offline jlj1
Re: Wire Limits
« Reply #2 on: February 01, 2009, 11:53:29 am »
Yeah in 2007 and the link is dead
Re: Wire Limits
« Reply #3 on: February 01, 2009, 12:01:50 pm »
Hmm, well, it's one line of code per cvar you add to the menu. I'm sure there's someone that will be kind enough to make a 5-minute script for you. :)
Offline ahref
Re: Wire Limits
« Reply #4 on: February 08, 2009, 09:46:33 am »
where would the limits sliders be added i have the commands:
ulx.addToMenu( ulx.ID_MADMIN, Max Wire lights :, { max=32, cvar="sbox_maxwire_lights " } )
but into which lua file should they be pasted :D?
thanks
Re: Wire Limits
« Reply #5 on: February 08, 2009, 10:08:59 am »
Create a file under modules. Doesn't matter what the file is named.
Offline Stephen304
Re: Wire Limits
« Reply #6 on: July 01, 2009, 08:36:30 am »
thanks
Hey can you give me the module file and the path to put it in? I don't know anything about how to do this stuff and i haven't been able to even FIND the variables fr the max wire stuff. thanks.
Re: Wire Limits
« Reply #7 on: July 01, 2009, 09:38:35 am »
If you need to find the variables, ingame, type in the console "find sbox_maxwire"
you will get a full list.
Offline Stephen304
Re: Wire Limits
« Reply #8 on: July 02, 2009, 08:10:42 am »
Oh, ok thanks. What do i call teh file?(what extension? .mod?)
And where is the module folder? There is one in Ulib somewhere and there's another in ulx.
« Last Edit: July 02, 2009, 08:02:05 pm by Stephen304 »
Re: Wire Limits
« Reply #9 on: July 02, 2009, 09:37:19 pm »
.lua
And, in the ulx modules..can't load using ULX menu commands if ULX isn't yet loaded.
Offline Stephen304
Re: Wire Limits
« Reply #10 on: July 03, 2009, 08:58:21 am »
I havent put the module in the place yet, but whenever i open the admin menu i get this:
ulx/modules/cl/adminmenu.lua:15: bad argument #1 to 'SetText' (string expected, got nil)
Is it something to worry about or not?
Offline Stephen304
Re: Wire Limits
« Reply #11 on: July 05, 2009, 04:37:45 pm »
And there are multiple module folders in the ulx addon folder, so can you specify a specific directory?
