Team Ulysses is proud to present our latest and greatest software: Ulysses (admin+) No Limited
Not compatible with Gmod13.
UnoLimited v1.1 (Basic) ;
- Does NOT require ULib
- Allows Admins to have no limits to any sbox_max<item here> server limit.
- Allows SuperAdmins to have no limits to any sbox_max<item here> server limit.
Download: ulyssesmod.net/JamminR/projects/UnoLimited_v1_1.zip
Unzip to your server's Gmod/addons folder.
GM13+ compatible, see news item below
UnoLimited v2 (ENHANCED) ;
- Requires ULib 2.4+
- Allows you to set a multiplier (0 to 2, can used decimals .75 , 1.5, etc) for each group you wish to control.
- Defaults to 1 (standard limit) if you do not set up a custom group.
- Allows setting a group 'unlimited' using "-1"
11/26/2012 - GM13 Update by community member "nexbr"!As I've pretty much lost interest, a community member has picked up the gauntlet!
See /index.php/topic,6720.0.html7/16/2010 - UPDATE - Thanks to AtomicSpark, he corrected linux compatibility issues for version 2(now 2.2)
Download: ulyssesmod.net/JamminR/projects/unolimited_v2_2.zip
Make sure to delete /addons/UnoLimited_v1* if you have it already.
Once unzipped, go into the addons/UnoLimited_v2/lua/ULib/modules folder, open the only file there, and edit the table at the top with any custom groups you wish to adjust. Save, restart server.
Please comment in this thread any ideas.
(No, I won't do a menu. This is meant to be a set and forget type addon.)
I'm already considering setting limits for admins within the file itself, at the most a variable set at the top of the file. Done in V2.
I must mention and give credit that this is 98% code from Garry's own functions.
Megiddo started a framework some time ago to go past those limits and functions (found in another thread)
I just edited some syntax issues, and packaged it nicely in addon format.
Team Ulysses - Striving for Simplicity.
v1.1 - Fixed Sent Check
v2 - ULib enhanced group limit control.
v2.1 -
Fixed CheckLimit and null value for "ply" errorv2.2 -
AtomicSpark corrected linux compatibility (case-sensitivity) - Thanks!
v2.3 -
nexbr made Enhanced version compatible for GMod 13 - Great!!
Edit - Split from the Release Archives. Accidentally moved, forgetting that nexbr had updated.
