Author Topic: Dedicated Server  (Read 7353 times)
Offline ninjacell
Dedicated Server
« on: February 01, 2009, 08:01:24 pm »
I made my Dedicated server for Garrys Mod. Other people can join it, but i cant. it gets stuck at connecting to server and cancels out after four retries. i also cant join in other servers. If you know whats wrong or have any idea it would be appreciated. Thank You.
Re: Dedicated Server
« Reply #1 on: February 01, 2009, 08:57:29 pm »
Hosting your server on your local network?
Or a true hosting company?
If a public hosting, no idea. Should work.
If local, don't use the 'internet' server list to connect to it.
Try the local LAN ip range. Like instead of <your cable modem ip>:port try <192.168.x.x>:port
From server list, see if it's listed in LAN servers.
Offline ninjacell
« Reply #2 on: February 01, 2009, 09:11:54 pm »
im hosting the server on my local network. i can see it on the LAN but i cant connect.
Offline ninjacell
« Reply #3 on: February 01, 2009, 09:13:13 pm »
im using a router, im not sure if that makes a difference. The IP I was using was 192.168.2.5 and port 27015
« Last Edit: February 01, 2009, 09:17:27 pm by ninjacell »
Offline WildWill
  • Global Moderator
    • Beast_Building_Server
« Reply #4 on: February 01, 2009, 11:13:29 pm »
The server that your hosting, is it on the same box that you play on? is the the "start dedicated server"button? or is this a full on setup of SRCDS an a separate machine on your network?
I have some suggestions on what you might could try but I'd be digging in the dark without knowing these things.
Offline ninjacell
« Reply #5 on: February 02, 2009, 09:01:57 am »
The Server Is Hosted On The Same Computer I Play On. Its The Start Dedicated Server Botton Thingy
