Author Topic: Toolmode issues (toolmode_allow_weld = 1 apparently = 0)  (Read 6623 times)
Offline Darksoul
« on: February 02, 2009, 01:59:52 am »
I just restricted a lot of toolmodes in my server. All of them apparently...
I've removed the code with them enabled, because I don't know what went wrong.
toolmode_allow_paint = 0
toolmode_allow_ignite = 0
toolmode_allow_wheel = 0
toolmode_allow_weld_ez = 0
toolmode_allow_turret = 0
toolmode_allow_trails = 0
toolmode_allow_thruster = 0
toolmode_allow_statue = 0
toolmode_allow_spawner = 0
toolmode_allow_rtcamera = 0
toolmode_allow_rope = 0
toolmode_allow_physprops = 0
toolmode_allow_nocollide = 0
toolmode_allow_muscle = 0
toolmode_allow_motor = 0
toolmode_allow_magnetise = 0
toolmode_allow_leafblower = 0
toolmode_allow_keepupright = 0
toolmode_allow_inflator = 0
toolmode_allow_hoverball = 0
toolmode_allow_finger = 0
toolmode_allow_faceposer = 0
toolmode_allow_eyeposer = 0
toolmode_allow_example = 0
toolmode_allow_emitter = 0
toolmode_allow_elastic = 0
toolmode_allow_dynamite = 0
toolmode_allow_duplicator = 0
toolmode_allow_colour = 0
toolmode_allow_camera = 0
toolmode_allow_balloon = 0
toolmode_allow_keypad_wire = 0
ulx toolallow ignite in server doesn't change it. Erm...
ideas on how to ENABLE the toolmodes I want enabled? :D.
Re: Toolmode issues (toolmode_allow_weld = 1 apparently = 0)
« Reply #1 on: February 02, 2009, 08:07:52 am »
May a suggest an alternative method? Check out URestrict in the Releases section.
Offline Darksoul
« Reply #2 on: February 02, 2009, 09:30:54 am »
Will that block the toolmode for the whole server or just per team?. Because when I disable them I want them removed, even for super admin.
Why was this moved in Off Topic... This is a ULX SVN issue....
« Reply #3 on: February 02, 2009, 10:24:49 am »
This doesn't have anything to do with ULX, you're using garrysmod commands.
Offline Darksoul
« Reply #4 on: February 02, 2009, 10:42:00 am »
Oh... I was looking this up in the search and stumbled upon it.
I was trying to figure out how to add the following into server.cfg so it updates ever server restart/mapchange (Unless it saves it?)
Category: Toolmodes
   o toolallow <toolmode> - Globally allows the use of the specified toolmode. (IE: "remover")
   o toolallowuser [<user>] <toolmode> - Allows a player the use of the specified toolmode.
   o tooldeny <toolmode> - Globally denies the use of the specified toolmode. (IE: "remover")
   o tooldenyuser [<user>] <toolmode> - Denies a player the use of the specified toolmode.
My bad, my apologies.
« Reply #5 on: February 02, 2009, 06:04:53 pm »
     - Server, unless told otherwise.
