Author Topic: Scripting a progressbar  (Read 9316 times)
Offline Master-Guy
« on: February 12, 2009, 10:38:43 am »
Hi all,
Currently I'm just playing around some with lua files to see what's possible and at this moment I'm trying to make a progressbar.
For now I got it working, but it's based on the FPS to fill.
The code I have for now (cl_init.lua):
function GM:HUDPaint()
    cntTest = cntTest+1
    cntPcnt = math.floor((300/cntMax)*cntTest)
    cntPcntD3 = math.floor(cntPcnt/3)
    if stopdraw == false then
        draw.RoundedBox(2, boxLeft, boxTop, cntPcnt, 25, Color(0, 255, 0) )
        draw.RoundedBox(2, boxLeft+cntPcnt, boxTop, 300-cntPcnt, 25, Color(255, 0, 0) )
        draw.SimpleText(cntPcntD3, "ScoreboardText", boxLeft+150, 47, Color(255,255,255,255), TEXT_ALIGN_CENTER, TEXT_ALIGN_CENTER)
    if cntPcnt >= 300 then
        stopdraw = true
cntTest = 0
cntMax = 1200
boxLeft = (ScrW()/2)-150
boxTop = 35
stopdraw = false
Is there any way to make it work on a timer with milliseconds or deciseconds?
Any help would be greatly appreciated.
With kind regards,
MG
Re: Scripting a progressbar
« Reply #1 on: February 12, 2009, 02:55:09 pm »
Lua Manual and Gmod Lua Wiki are your friends. :)
I suggest the following.
os.time - Though a standard Lua function, I link to the Gmod wiki most of the time just to keep links to one place. Amazing what the "See also" links often can help give ideas for.
String.ToMinutesSecondsMilliseconds
Offline Master-Guy
« Reply #2 on: February 14, 2009, 01:33:20 am »
Thanks for your reply, but I've found those already :P
Unfortunately I cannot get those get to work with milliseconds :(.. the smallest is seconds :'(
« Reply #3 on: February 14, 2009, 05:53:36 am »
You'd need to provide a time in seconds that also included decimals to the String.ToMinutesSecondsMilliseconds function for it to hand back milliseconds.
I thought that os.time didn't do any rounding.
I'm not sure how you've tested but all the numbers currently in your script have have no decimals.
Offline Master-Guy
« Reply #4 on: February 14, 2009, 11:18:10 am »
I finally got it working..
Before today I tought that the timer function only worked with integers, but today I spotted the word "float" in the description and tested that..
It seems to do the trick.
        stopdraw = true
print(string.ToMinutesSecondsMilliseconds(1234.5678))
function advanceProgressA()
cntTest = cntTest + 1
if cntTest < cntMax then
timer.Create("ProgressTimerB", 0.1, 1, advanceProgressB, "")
function advanceProgressB()
timer.Create("ProgressTimerA", 0.1, 1, advanceProgressA, "")
function startProgress(durationMS)
cntMax = math.Round(durationMS/10)
cntTest = 0
stopdraw = false
startProgress(3000)
