Author Topic: I cant get Ulysses mod work anymore ;\ Sometime ago worked.  (Read 4403 times)
Offline ETTTETT
« on: February 19, 2009, 10:53:33 am »
Says in console:
AdvDupeShared: Server Compression: false
===  Wire  923   Installed  ===
Warning: Unhandled usermessage 'ulib_sound'
This server is running ULib version 2.21.
RunConsoleCommand blocked - sent before player spawned (ulib_cl_ulib_loaded)
--- Missing Vgui material texturemissing
Redownloading all lightmaps
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
Warning: Unhandled usermessage 'SendMotdMenu'
Idk how fix :P
Re: I cant get Ulysses mod work anymore ;\ Sometime ago worked.
« Reply #1 on: February 19, 2009, 10:59:19 am »
Are you running the latest SVN version or the latest release?
Offline ETTTETT
« Reply #2 on: February 19, 2009, 11:01:18 am »
Umh :O
I downloaded this from Ulyssesmod.net at the index.
« Reply #3 on: February 19, 2009, 11:07:12 am »
Visit the SVN forum here.. that is the latest unreleased version. Im nt sure, but it might fix your problem.. i know there are a few issues with the released version with a recent GMod update.
Offline ETTTETT
« Reply #4 on: February 19, 2009, 11:14:42 am »
Thank you. I realized the first message in the SVN version is out there and I went to look for so I found it. Thank you.
I use translator :D
« Last Edit: February 19, 2009, 11:16:22 am by ETTTETT »
