Author Topic: Menus Not Working  (Read 9142 times)
Offline Samusaaron3
Menus Not Working
« on: February 21, 2009, 11:02:02 am »
My menu's (ulx adminmenu, ulx mapsmenu etc) no longer show up. I get different errors for the different menus.
adminmenu: "[ULIB] Error, received invalid lua"
mapsmenu: "Warning: Unhandled usermessage 'SendMapsMenu'"
etc.
« Last Edit: February 21, 2009, 11:40:45 am by Samusaaron3 »
Re: Menus Not Working
« Reply #1 on: February 21, 2009, 11:55:00 am »
What SVN revision are you using?
Offline Samusaaron3
« Reply #2 on: February 21, 2009, 12:10:21 pm »
The most recent (tried updating this morning in order to try to fix it)
Offline Wolfy
« Reply #3 on: February 23, 2009, 02:07:23 am »
I am having the exact same problem.
Console commands work fine, but the command autocompletes don't show up when typing commands out in console, and I get the same errors as Samusaaron3 when trying to use the menus.
Offline Samusaaron3
« Reply #4 on: February 23, 2009, 05:09:27 am »
I get that too.
« Reply #5 on: February 23, 2009, 02:17:29 pm »
Garry must have released more 'fixes' for Gmod, or Valve did.
Make sure you're not all using scripts that monitor for 'chat' commands, specifically ones that use an exclamation point as the lead.
A very popular one right now does it horribly, and it breaks all other scripts that might use them.
Offline PowerHouse
« Reply #6 on: April 13, 2009, 07:21:47 pm »
well i have the exact same problem as well. so what do we do? ???
« Reply #7 on: April 13, 2009, 08:08:22 pm »
What revision of SVN are you using?
Most have seen this error gone after going to SVN.
Offline ultradude25
« Reply #8 on: April 28, 2009, 07:22:06 pm »
I get this in the console as soon as I finish joining my server:
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ulx_map'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
Warning: Unhandled usermessage 'SendMotdMenu'
The strange thing is, it works fine in singleplayer. I actually copied the ulib and the ulx folders from my servers addons folder directly into my garrysmod addons folder. So everything should be exactly the same. The server is completly fresh and doesn't have any other addons installed.
I can use all commands but anything that requires a menu (Including the MOTD) doesn't work and gives me:
I've also tried the most recent SVN version on my server and (After deleting ULX from my local garrysmod) it works fine, so there is a problem with the non-SVN version.
I used version 3.31, ULX SVN Revision 27 and ULib SVN Revision 26. I obviously didn't use the SVN and normal version at the same time.
« Last Edit: April 28, 2009, 07:25:13 pm by ultradude25 »
« Reply #9 on: April 28, 2009, 07:27:54 pm »
Are you using sv_downloadurl?
Offline bennie900
« Reply #10 on: August 08, 2009, 03:01:35 am »
First error upon join:
ulx/cl_init.lua:22: attempt to call field 'getVersion' (a nil value)
Warning: Unhandled usermessage 'ulx_addMenuItem'
ULib/shared/sh_ucl.lua:244: attempt to call field 'umsgRcv' (a nil value)
ULib/shared/sh_ucl.lua:257: attempt to index upvalue 'curTable' (a nil value)
ULib/shared/sh_ucl.lua:251: attempt to call field 'umsgRcv' (a nil value)
Warning: Unhandled usermessage 'ulib_repWriteCvar'
None of the menu's work, when i try to access any i get (in console):
({SM})SO.Bennie: !menu
Warning: Unhandled usermessage 'ULibLuaFn'
Looks like the same error as above. I'm using revision 37 or ulib and 40 of ulx, and yes im using sv_downloadurl, does it need to be on the HTTP server? if so what files?
Thanks.
« Last Edit: August 08, 2009, 06:11:08 am by bennie900 »
« Reply #11 on: August 08, 2009, 06:50:19 am »
The servers /cache folder should always be available on the fast download server. This will usually correct missing client side scripts/functions for players, Ulysses related or not. Any time you add a new addon, restart server so that cache rebuilds, then put the cache on the fast upload.
Offline bennie900
« Reply #12 on: August 08, 2009, 07:55:44 am »
Oh yer! duh forgot to re upload when i saw the new LUA files, all works now.
