Author Topic: ULib breaks datastream  (Read 7031 times)
Offline thomasfn
« on: March 08, 2009, 08:07:47 am »
Sorry if this is in wrong place, or w/e.
Already sent off a bug report about this:
http://ulyssesmod.net/bugs/view.php?id=348
But it's important this is fixed asap.
When using the datastream module (now included in GMod by default) clientside, ULib errors out and datastream fails to deliver data.
Using datastream.StreamToServer on the client. Error is serverside.
ULib/server/hook.lua:139: attempt to index local 'gm' (a nil value)
This causes compatability issues with PCMod 2, stopping a core feature from working. Any other mod that uses clientside datastream will break completely.
This is not a problem with my code, or datastream code, but with ULib overriding the hook library badly. It needs to be fixed asap, since ULX is basically breaking a GMod function.
Many people use PCMod 2 and ULX on their servers, and since PCMod 2 uses clientside datastream, ULX breaks it.
Re: ULib breaks datastream
« Reply #1 on: March 08, 2009, 10:21:42 am »
Argh. I told the author of Datastream not to do this; guess he didn't listen to me.
Offline thomasfn
« Reply #2 on: March 08, 2009, 01:50:49 pm »
Well, I don't know how much of this is LuaBanana's fault, or what exactly the problem is, but is there a chance you could add the fix into the next release/svn? I'm getting alot of complaints that the save feature is not working, and I don't want to have to give people a file to override hook.lua with. (I posted a fix on mantis)
« Reply #3 on: March 08, 2009, 02:15:26 pm »
Testing the change now... will have it on SVN later today as long as it doesn't break anything.
EDIT: Fixed in rev 24
« Last Edit: March 08, 2009, 02:45:23 pm by Megiddo »
