Author Topic: Any problems?  (Read 9836 times)
Any problems?
« on: March 19, 2009, 04:02:28 pm »
Rolled out a few more updates on both ulib and ulx. Let me know if there's any issues pronto.
Offline scfanatic
Re: Any problems?
« Reply #1 on: March 20, 2009, 04:35:31 pm »
hi, i just update my server to revision 25, and now whenever i add a superadmin ,including my self, as soon as i log out i lose my status as a super admin, i even checked the user.txt and im registered as a user, any help?  :-\
im using uclip and ulx explode as extra ulx mods on the server if that changes anything
Offline JOE
Re: Any problems?
« Reply #3 on: March 21, 2009, 04:00:47 pm »
Hi, I registered to post an issue i'm having with ULX mod, That i just recently encountered after the latest SVN update.
Since the newest ulx (SVN) update , Whenever i ragdoll a player, They stay ragdolled even if i try to !unragdoll them.
I was testing it on myself, I ragdolled myself, And !unragdoll would not work. I then typed "Kill" in console, Which respawned me like normal, But i was unable to use any other ULX commands, it would say "You are ragdolled!" and my player ragdoll did not dissapear, and was still in the same spot.
If it helps, This is the line of code i get in my console when i attempt to unragdoll myself.
ulx\modules/fun.lua:884: attempt to index field 'ragdoll' (a nil value)
This could just be me, i'm not sure, But i was not having these issues prior to applying the latest SVN update to my ULX/Ulib folders.
« Last Edit: March 21, 2009, 04:47:23 pm by JOE »
Re: Any problems?
« Reply #4 on: March 22, 2009, 09:52:07 pm »
It wasn't just you. It should be fixed now. Thanks!
Offline [WCA]AIDS
    • PlanetWCA Forums
Re: Any problems?
« Reply #5 on: March 23, 2009, 05:32:45 pm »
Currently I am using ULX revision 27 and ULib revision 25 on both of my servers.
JamminR mentioned in another thread that Garry had broken the way Ulib initializes, and that does seem to be the problem.
I hope that this information can possibly help.
These are the error messages clients receive in their console:
Lua initialized (Lua 5.1)
RunConsoleCommand blocked - sent before player spawned (ulib_cl_loaded)
RunConsoleCommand blocked - sent before player spawned (ulib_cl_ulib_loaded)
Redownloading all lightmaps
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ulx_map'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
Warning: Unhandled usermessage 'SendMotdMenu'
Additionally the following is also returned:
ulx menu
[ULIB] Error, received invalid lua
There is probably more errors that I am unable to discover, currently I am unable to even launch GMod, and as such can only use what people tell me.
OT:
Hi Megiddo :)
Re: Any problems?
« Reply #6 on: March 23, 2009, 06:49:07 pm »
WCA-Aids,
Do you use each server for the download host? Or do you use one server, totally separate, from the two game servers as your download server?
I've not seen anyone complain of initialization errors in quite a while, except for when the download server didn't contain the latest cached lua files (or the client couldn't download the cache (filtered/blocked)) for download.
Though yes it could have sprung up again, please make sure your download server has the latest cache created by either server running the latest SVNs.
Re: Any problems?
« Reply #7 on: March 23, 2009, 07:12:41 pm »
ulx menu
OT:
Hi Megiddo :)
The symptoms sound the same as before we fixed garry's breakage in SVN. Please ensure that you are, in fact, running SVN. :)
Offline [WCA]AIDS
    • PlanetWCA Forums
Re: Any problems?
« Reply #8 on: March 23, 2009, 07:41:46 pm »
WCA-Aids,
Clients download the files from the gameservers themselves, I do not employ a separate server handling file downloads, nor any type of FastDL. I am under the impression that the cached files are fresh, tho I may indeed be wrong. I will check now, but I can't guarantee any results, TC-Admin isn't my friend.
Edit: Yes, all cached files are fresh. So is everything else. (except for the gamemode files, but that is irrelevant.)
I uploaded the newest revisions manually myself. As well as have issued multiple server restarts.
« Last Edit: March 23, 2009, 07:54:15 pm by [WCA]AIDS »
Offline spbogie
Re: Any problems?
« Reply #9 on: March 24, 2009, 06:56:33 am »
Make sure there isn't an older version of ULib/ULX installed on the client that may be interfering with the updated one from the server. If that's not the case, try deleting the cache and letting the server rebuild it.
Any other information you can give about the servers is always helpful. Gamemode, other addons, etc... There's always the possibility of a conflict, and even if the information doesn't immediately point to something having it for the record if more reports come in makes it much easier to narrow down the source.
Offline [WCA]AIDS
    • PlanetWCA Forums
Re: Any problems?
« Reply #10 on: March 24, 2009, 04:30:58 pm »
-snip-
Somehow I fixed my issues.
« Last Edit: April 02, 2009, 04:24:47 pm by [WCA]AIDS »
Re: Any problems?
« Reply #11 on: April 25, 2009, 09:58:39 am »
Okay, now we got that user problem fixed... any other problems? :P
Re: Any problems?
« Reply #12 on: April 25, 2009, 08:56:52 pm »
I split the off-topicness to /index.php/topic,4008
Re: Any problems?
« Reply #13 on: May 08, 2009, 04:16:56 pm »
It's been over a week and no new reports, unless someone has complaints they want to make, I'm going to aim for release tonight or tomorrow.
