Author Topic: Ulx wont keep my admin status  (Read 19622 times)
Offline igiz
Re: Ulx wont keep my admin status
« Reply #16 on: April 02, 2009, 02:14:12 pm »
K,I got it working.Tas was right when you set ULib.UCL_LOAD_DEFAULT to false it does work and your admin status is saved It was my bad that I didn't get to work in the first time as I had put a . before false by accident but now it's all working fine.
Offline freefry
« Reply #17 on: April 03, 2009, 08:24:32 pm »
I can confirm, this fixed it, now my users.txt file is not spammed with all users that connects, and neither does it repeatedly re-add users with special chars in their name.
Thanks for this. :)
Offline PowerHouse
« Reply #18 on: April 13, 2009, 02:53:38 pm »
That indeed fixed it! problem solved.... Now for the menu....
Offline Newskin01
« Reply #19 on: April 22, 2009, 03:49:50 pm »
This fixes it if you edit the one in shared.  Any user who joins downloads the lua that you edited.  When I did it I still have problems so I just deleted everything and started fresh edited that lua and it worked.  Good luck.
