Author Topic: ULX Rocket  (Read 82369 times)
Offline CTO_7
Re: ULX Rocket
« Reply #15 on: December 13, 2009, 05:10:03 am »
Got this error in console:
"ulx\modules/rocketsvn.lua:3: attempt to index local 'target_plys' (a nil value)"
And even though im a superadmin it says I didn't have access to the command could only run through console
Offline vader0146
Re: ULX Rocket
« Reply #16 on: December 13, 2009, 05:31:19 am »
ok what the   :o
everything I post seems to be broken for all servers except mine and my friends  :o
Offline NaRyan
Re: ULX Rocket
« Reply #17 on: December 13, 2009, 06:36:28 am »
ok what the <censor>  :o
I just tried this as ulx rocket was one of my favourite toys :p
but I also get the "ulx\modules/rocketsvn.lua:3: attempt to index local 'target_plys' (a nil value)" error
That was on both a Listen server and a Lan dedicated server, with only ULib, ULX and ULX Rocket as addons.
No extra maps, no extra game content loaded (just stock gmod), no extra lua files in lua/autorun..
I even tried a clean install on ulib/ulx on lan server, by deleting their folders in addons, and Ulib folder in data. cleaned out the cache\dua folder.
Redownloading via svn, starting server, joining, adding myself back as superadmin, disconnecting, re-connecting.
But still no joy :(
Offline vader0146
Re: ULX Rocket
« Reply #18 on: December 13, 2009, 10:11:43 am »
You could try this one I suppose
Re: ULX Rocket
« Reply #19 on: December 13, 2009, 10:30:33 am »
Vader, did you try that with multiple players/teams?
like ulx rocket JamminR,Bob,Vader0146
The code seems it would only do JamminR in above example
Offline CTO_7
Re: ULX Rocket
« Reply #20 on: December 13, 2009, 01:07:17 pm »
Still get this error:
ulx\modules/rocketsvn.lua:3: attempt to index local 'target_ply' (a nil value)
and also still don't have access to the command.
Re: ULX Rocket
« Reply #21 on: December 13, 2009, 04:42:58 pm »
Vader, make sure you're locally setting "CATEGORY_NAME" in the scripts you convert.
That's not a global ULX variable. It's used to tell the command what section of "ulx help" to go in.
local CATEGORY_NAME = "Fun" is a good one for the rocket.
As that variable is in the first line of the <command object>:<setup commands>, it causes the rest of the command to fail.
All, I've converted rocket for ULX 3.5+ (currently SVN as of this post)
See attached. Let me know if you have errors.
If ahref comes along and wants he can post this to his original release.
Remove your "rocket" folder from addons before adding this one. I've renamed the folder to indicate its for ulx35
CTO, if this doesn't work for you, make sure the group you're in inherits admin in it's chain somewhere.
« Last Edit: December 13, 2009, 04:54:51 pm by JamminR »
Offline CTO_7
Re: ULX Rocket
« Reply #22 on: December 13, 2009, 05:31:54 pm »
Works great only thing its really missing is the trail and the !rocket command and the group was ulx default superadmin.
Offline NaRyan
Re: ULX Rocket
« Reply #23 on: December 13, 2009, 06:42:41 pm »
I see the coloured trail from "Rocketed" peeps....  ???
Re: ULX Rocket
« Reply #24 on: December 13, 2009, 07:24:50 pm »
Missing from vader? Or mine?
Yeah, his was broken. He had the right setup for it, just missing a variable that would keep it all from working.
However, if using the conversion I did, and you're missing !rocket and color trails...you either have a conflicting mod, or you didn't delete the original addons\rocket folder. (Which, in it's own right, would be a conflict)
Offline CTO_7
Re: ULX Rocket
« Reply #25 on: December 13, 2009, 11:11:50 pm »
No sorry I was mistaken they were both there just had tested on myself and couldn't see my own trail.
Offline Gmods
Re: ULX Rocket
« Reply #26 on: January 02, 2010, 08:57:23 am »
I've put this in /addons and in /addons/ulx but it won't work.
Re: ULX Rocket
« Reply #27 on: January 02, 2010, 02:09:58 pm »
When reporting issues, never ever just say "it doesn't work".
Give errors, versions you're running, any other details.
When Gmod Lua scripts don't work, there will almost always be an error at server startup in server console, or a server console error when the command is run.
What version of ULX are you running?
Most old modules don't work with SVN, but rocket has two versions. One for ULX release in the first post, and one for SVN. here - /index.php/topic,3955.15.html#msg17523 />zip file attached to my post...remove the old one from all locations you installed it.
Both versions go in /addons, not /addons/ulx
Offline Gmods
Re: ULX Rocket
« Reply #28 on: January 03, 2010, 01:31:57 pm »
I am using the SVN version and I hadn't downloaded the one in the link you provided. Will give it a shot.  Thanks.
Offline ahref
Re: ULX Rocket
« Reply #29 on: January 08, 2010, 05:38:40 am »
Im back. Went on hiatus from gmod for a bit whilst i did some Academic work.
Thanks for fixing this for the new svn. Is there a guide for converting old modules I have a few unreleased ones that are bugging up :D.
Ill add it to the front post.
