Author Topic: Garry's Mod Update 61 Problems  (Read 7838 times)
Offline Corvx
« on: March 27, 2009, 06:34:06 am »
Just wanted to inform anyone who's having problems after the new update to Gmod.
Type +sv_scriptenforcer 1 at the end of your launch parameters of your server.
ex.
srcds.exe -game garrysmod -maxplayers 10 -console +map gm_wireconstruct_rc +sv_scriptenforcer 1
That helped me.
I hope I posted this in the right section.
Offline Gmods
Re: Garry's Mod Update 61 Problems
« Reply #1 on: March 28, 2009, 06:15:57 am »
This works yes, but it seems to kick people who have custom scripts? Two people have been kicked from my server for the following reason...
Player NAME left the game (Kicked by Console : "Mismatch: effects\propspawn\init.lua")
« Reply #2 on: March 28, 2009, 06:53:45 am »
Odd, it appears that garry's no longer sending out custom lua files at all unless script enforcer is enabled. Confirmed, Corvx's solution fixes the bug in garry's latest update.
At least... I hope it's a bug. I can't see why he'd purposely not want to send lua files unless script enforcer was enabled.
Offline Gmods
« Reply #3 on: March 28, 2009, 09:35:21 am »
Is there anyway to stop it kicking players with the error I posted above?
« Reply #4 on: March 28, 2009, 10:02:08 am »
If you're using sv_downloadurl, you need to delete your old cache and rebuild it.
Offline Gmods
« Reply #5 on: March 28, 2009, 10:04:09 am »
I'm not using it.
Offline DiscoBiscuit
    • DiscoBuild
« Reply #6 on: March 28, 2009, 05:56:41 pm »
Is there any way to stop the kicking of clients? It kicks them when they take out a stargate weapon or click on any tool. I tried scriptenforce_createmanifest but it didn't create a clientscripts.txt
« Last Edit: March 28, 2009, 06:23:04 pm by DiscoBiscuit »
« Reply #7 on: March 28, 2009, 06:22:34 pm »
Garry made it so you don't need to modify clientscripts.txt anymore
Offline Gmods
« Reply #8 on: March 29, 2009, 06:38:41 am »
I found if you type sv_scriptenforcer1 in console, then reload the map, then turn it off. ULX will still function properly and clients will be able to use the tool guns.
Offline ahref
