Author Topic: Menu Problems  (Read 6466 times)
Offline Gmods
Menu Problems
« on: March 27, 2009, 05:34:16 pm »
I've recently downloaded ULX from both SVN and the front page. It installs fine and I can run the Admin commands via chat (!jail !slay etc) but I cannot bring up the Admin menu. I have tried typing "ulx menu" and typing !menu in game but none of these work.
Console also doesn't display anything when I type "ulx help" in console either. Any soloutions?
Offline EDGE
Re: Menu Problems
« Reply #1 on: March 28, 2009, 09:28:58 am »
I am having the same problem.
Recently set up up a new server with the HLDS Update Tool which was easy enough and worked fine (so this is a fresh install... no other addons). I downloaded the ULX/ULIB .exe installer and  I can run commands such as !jail, !slay, !slap, etc... but it seems as though any command that would require a menu to pop up does not appear (neither the admin menu nor MOTD will show up).
Just FYI, I added my steam ID to the Super Users group so I should have access to the command. There is no error unless I try typing the command via rcon in which case it gives an error that says it has to be run in game to display the popup (makes sense).
Re: Menu Problems
« Reply #2 on: March 28, 2009, 10:01:29 am »
Garry broke the lua file download system in the last update, enable script enforcer to make the server give you the files.
Offline cobrasvt1999
Re: Menu Problems
« Reply #3 on: July 17, 2009, 05:38:09 am »
i have a similar problem, i booted the server and when i get on i get no welcome message and the "!menu" command dose not work neither does "ulx adminmenu". i can jail, slap, gag and all other commands but still no menu. i tried to set sv_scriptenforcer 1
but all that did was begin spewing out more errors and seemed to break ulx entirely, also tab no longer works and the "Q' menu breaks. put it back on 0 and back to square one.......
Error is as follows:
ScriptEnforce: "autorun\base_npcs.lua" blocked
ScriptEnforce: "autorun\base_npcs_weapons.lua" blocked
ScriptEnforce: "autorun\base_vehicles.lua" blocked
ScriptEnforce: "autorun\developer_functions.lua" blocked
ScriptEnforce: "autorun\options_menu.lua" blocked
ScriptEnforce: "autorun\utilities_menu.lua" blocked
ScriptEnforce: "autorun\cs_playermodels.lua" blocked
ScriptEnforce: "autorun\ep2_entities.lua" blocked
ScriptEnforce: "autorun\ep2_npcs.lua" blocked
ScriptEnforce: "autorun\ep2_playermodels.lua" blocked
ScriptEnforce: "autorun\ep2_vehicles.lua" blocked
ScriptEnforce: "autorun\phx_content.lua" blocked
ScriptEnforce: "autorun\tf_concommands.lua" blocked
ScriptEnforce: "autorun\tf_gm_hooks.lua" blocked
ScriptEnforce: "autorun\tf_npc_spawnmenu.lua" blocked
ScriptEnforce: "autorun\add_materials.lua" blocked
ScriptEnforce: "autorun\sv_uclip.lua" blocked
ScriptEnforce: "autorun\opcodes.lua" blocked
ScriptEnforce: "autorun\wiremodadmin.lua" blocked
autorun/client/client_fonts.lua:26: attempt to index global 'hook' (a nil value)
autorun/client/client_hud.lua:529: attempt to index global 'hook' (a nil value)
ERROR! Module 'zlib_b64' not found!
RunConsoleCommand blocked - sent before player spawned (ZLib_Installed)
autorun/shared/dupeshare.lua:23: attempt to index global 'usermessage' (a nil value)
autorun/client/cl_advdupe.lua:23: attempt to index global 'usermessage' (a nil value)
--- Missing Vgui material modelsduckehuttons
=== Loading Wire Model Packs ===
autorun/client/cl_modelplug.lua:9: attempt to call field 'KeyValuesToTable' (a nil value)
loading materials
autorun/client/cl_wirelib.lua:9: attempt to index global 'list' (a nil value)
ScriptEnforce: "autorun\client\player_info.lua" blocked
ScriptEnforce: "autorun\client\ups_preinit.lua" blocked
ScriptEnforce: "postprocess\bloom.lua" blocked
ScriptEnforce: "postprocess\categories.lua" blocked
ScriptEnforce: "postprocess\color_modify.lua" blocked
ScriptEnforce: "postprocess\dof.lua" blocked
ScriptEnforce: "postprocess\morph.lua" blocked
ScriptEnforce: "postprocess\motion_blur.lua" blocked
ScriptEnforce: "postprocess\overlay.lua" blocked
ScriptEnforce: "postprocess\sharpen.lua" blocked
ScriptEnforce: "postprocess\stereoscopy.lua" blocked
ScriptEnforce: "postprocess\sunbeams.lua" blocked
ScriptEnforce: "postprocess\super_dof.lua" blocked
vgui/dimagebutton.lua:13: attempt to call global 'AccessorFunc' (a nil value)
vgui/dlistview.lua:30: attempt to call global 'AccessorFunc' (a nil value)
ScriptEnforce: "vgui\contextbase.lua" blocked
ScriptEnforce: "vgui\fingerposer.lua" blocked
ScriptEnforce: "vgui\fingervar.lua" blocked
ScriptEnforce: "vgui\imagebutton.lua" blocked
ScriptEnforce: "vgui\imagecheckbox.lua" blocked
ScriptEnforce: "vgui\material.lua" blocked
ScriptEnforce: "vgui\matselect.lua" blocked
ScriptEnforce: "vgui\propselect.lua" blocked
ScriptEnforce: "vgui\slidebar.lua" blocked
ScriptEnforce: "vgui\toolquickselect.lua" blocked
ScriptEnforce: "vgui\toolquickselect_properties.lua" blocked
ScriptEnforce: "vgui\vgui_panellist.lua" blocked
ScriptEnforce: "vgui\dalphabar.lua" blocked
ScriptEnforce: "vgui\dbevel.lua" blocked
ScriptEnforce: "vgui\dbutton.lua" blocked
ScriptEnforce: "vgui\dcategorycollapse.lua" blocked
ScriptEnforce: "vgui\dcheckbox.lua" blocked
ScriptEnforce: "vgui\dcolorcircle.lua" blocked
ScriptEnforce: "vgui\dcolorcube.lua" blocked
ScriptEnforce: "vgui\dcoloredbox.lua" blocked
ScriptEnforce: "vgui\dcolormixer.lua" blocked
ScriptEnforce: "vgui\dcombobox.lua" blocked
ScriptEnforce: "vgui\dform.lua" blocked
ScriptEnforce: "vgui\dframe.lua" blocked
ScriptEnforce: "vgui\dgrid.lua" blocked
ScriptEnforce: "vgui\dhorizontaldivider.lua" blocked
ScriptEnforce: "vgui\dhorizontalscroller.lua" blocked
ScriptEnforce: "vgui\dimage.lua" blocked
ScriptEnforce: "vgui\dkillicon.lua" blocked
ScriptEnforce: "vgui\dlabel.lua" blocked
ScriptEnforce: "vgui\dlistview_column.lua" blocked
ScriptEnforce: "vgui\dlistview_line.lua" blocked
ScriptEnforce: "vgui\dmenu.lua" blocked
ScriptEnforce: "vgui\dmenuoption.lua" blocked
ScriptEnforce: "vgui\dmodelpanel.lua" blocked
ScriptEnforce: "vgui\dmultichoice.lua" blocked
ScriptEnforce: "vgui\dnotify.lua" blocked
ScriptEnforce: "vgui\dnumberwang.lua" blocked
ScriptEnforce: "vgui\dnumpad.lua" blocked
ScriptEnforce: "vgui\dnumslider.lua" blocked
ScriptEnforce: "vgui\dpanel.lua" blocked
ScriptEnforce: "vgui\dpanellist.lua" blocked
ScriptEnforce: "vgui\dpanelselect.lua" blocked
ScriptEnforce: "vgui\dpropertysheet.lua" blocked
ScriptEnforce: "vgui\drgbbar.lua" blocked
ScriptEnforce: "vgui\dscrollbargrip.lua" blocked
ScriptEnforce: "vgui\dshape.lua" blocked
ScriptEnforce: "vgui\dslider.lua" blocked
ScriptEnforce: "vgui\dsprite.lua" blocked
ScriptEnforce: "vgui\dsysbutton.lua" blocked
ScriptEnforce: "vgui\dtextentry.lua" blocked
ScriptEnforce: "vgui\dtinybutton.lua" blocked
ScriptEnforce: "vgui\dtooltip.lua" blocked
ScriptEnforce: "vgui\dtree.lua" blocked
ScriptEnforce: "vgui\dtree_node.lua" blocked
ScriptEnforce: "vgui\dtree_node_button.lua" blocked
ScriptEnforce: "vgui\dverticaldivider.lua" blocked
ScriptEnforce: "vgui\dvscrollbar.lua" blocked
ScriptEnforce: "vgui\spawnicon.lua" blocked
ScriptEnforce: "skins\default.lua" blocked
ScriptEnforce: "skins\example.lua" blocked
Re: Menu Problems
« Reply #4 on: July 17, 2009, 03:13:57 pm »
Cobra,
The menu not working was before our latest release of version 3.40. The post you replied to from Megiddo is from almost 4 months ago and many SVN updates even before our release.
Make sure you have the latest version of both ULX and ULib installed on your server.
Has there been any GMod update in the past few days?
Re: Menu Problems
« Reply #5 on: July 17, 2009, 05:24:27 pm »
yesterday, but it didn't work before that, i knew that it was 4 months old but I'm pretty sure that i do have the up to date version of ulx and ulib. i will double check though.
« Last Edit: July 17, 2009, 05:33:47 pm by cobrasvt1999 »
Re: Menu Problems
« Reply #6 on: July 17, 2009, 05:33:52 pm »
I see my mistake, thank you!
