Author Topic: UTime - Times are reset on map change/server restart! Help? ='(  (Read 7223 times)
Offline lolol
Hey everyone! I'm having a very wierd problem... I have UTime installed, and it works just fine, only problem is that if I run a map change or server restart, the times get reset! And I can't see the folder in garrysmod/data that I believe UTime should create...
Anyone know a fix to this?
Thanks in advance!  ;D
« Last Edit: April 07, 2009, 06:18:35 pm by lolol »
Re: UTime - Times are reset on map change/server restart!
« Reply #1 on: April 07, 2009, 06:00:31 pm »
UTime doesn't use a plain text file for data. Make sure you have a file in the garrysmod root named something like sv.db and that it's not set to be read-only.
Offline lolol
« Reply #2 on: April 07, 2009, 06:11:38 pm »
I have the sv.db file there, and it's not real only. =[
Offline lolol
Re: UTime - Times are reset on map change/server restart! Help? ='(
« Reply #3 on: April 07, 2009, 06:27:22 pm »
Any other possible causes to this issue? ???
Offline lolol
« Reply #4 on: April 08, 2009, 01:33:02 am »
Bump. I need a solution  :'(
« Reply #5 on: April 08, 2009, 06:45:02 am »
Well, I was going to help you but I make it a point not to answer people who bump every 15 minutes.
