Author Topic: URestrict is possibly conflicting with ULX?  (Read 4929 times)
Offline cheiftiger
« on: April 15, 2009, 07:15:17 pm »
Hello all,
When I installed URestrict it basically blocked me from ALL of my ULX commands (even motd and help!). But for some reason, It allows me to edit URestrict and still says I am an admin so could there possibly be a conflict between ULX and URestrict?
Also, it seems that when I add too many tool restrictions to the restrictions list, when I add another it says I've added it, and it's blocked, but the button won't appear in the restrictions menu. Also, when I add an extra one once I reach "the limit" it spams
Warning: Unhandled usermessage ''
in the console, and it spams it again if I close and re-open the URestrict menu. After a little while, I checked the menu again, and the tool I had tried to add was there now, and I checked the console and it didn't spam me with the usermessage stuff (I reopened the menu around 5 times just to make sure it was fixed  :D). Then I tried adding another, and it did the exact same thing. Do you think possibly a pre-load could fix this issue?
Please answer ASAP
Much appreciated,
Cheif Tiger
Re: URestrict is possibly conflicting with ULX?
« Reply #1 on: April 25, 2009, 09:53:17 am »
URestrict shouldn't block you from ULX commands at all. What version of ULX are you using?
