Author Topic: No menus work!  (Read 5880 times)
Offline red ryder
No menus work!
« on: June 16, 2009, 12:20:19 pm »
So, for months now, we haven't been able to get any of the ULX menus to work on our server. I think at some point a garrysmod update might have broken it, but I want to get it fixed once and for all. Essentially, anything related to UI ULX can't display. So, for example, I go into the console and I get the following:
] ulx adminmenu
[ULIB] Error, received invalid lua
] ulx banmenu
Warning: Unhandled usermessage 'SendBanMenu'
] ulx clientmenu
] ulx mapsmenu
Warning: Unhandled usermessage 'SendMapsMenu'
] ulx menu
] ulx motd
Warning: Unhandled usermessage 'SendMotdMenu'
Any ideas what's going on? Also, when I first join the server I get this console dump (huge):
Warning: Unhandled usermessage 'ulx_resetinfo'
Warning: Unhandled usermessage 'ulx_autocomplete'
Warning: Unhandled usermessage 'ulx_map'
Warning: Unhandled usermessage 'ULXMotdStart'
Warning: Unhandled usermessage 'ULXMotdText'
Warning: Unhandled usermessage 'ULXMotdEnd'
« Last Edit: June 16, 2009, 12:25:02 pm by red ryder »
Re: No menus work!
« Reply #1 on: June 16, 2009, 04:55:08 pm »
Looks like your clients aren't receiving the ulx files. Did you set up sv_downloadurl correctly? Running script enforcer?
Re: No menus work!
« Reply #2 on: June 16, 2009, 09:19:53 pm »
And make sure you're running SVN.
As stated (unknown but definitely in double digits now) times in this forum... yes.. our release is broken.
SVN should work as long as your clients are getting the files
Offline red ryder
Re: No menus work!
« Reply #3 on: June 17, 2009, 05:13:43 pm »
We don't have a downloadurl set up but the clients have been able to download everything else fine before. Would I have to set one up to get this to work? Also no, we don't use scriptenforcer.
Re: No menus work!
« Reply #4 on: June 17, 2009, 07:18:47 pm »
Are you using the ULX and ULib SVN?
Offline Lexicality
Re: No menus work!
« Reply #5 on: June 18, 2009, 09:42:56 am »
I am having this issue on a brand new ulx/ulib svn install, without a sv_downloadurl on a shared thingie that someone gave me. The clients download the files because I saw them being sent to me. The rest of the thing works fine, it's just the menus that don't. I set myself to be superadmin via users.txt.
