Author Topic: Adv Problem  (Read 8040 times)
JackBauer
Adv Problem
« on: July 13, 2009, 07:54:15 am »
Hi,
Anyone can spawn npc,weapons with ADV. Why can i stop that?
Re: Adv Problem
« Reply #1 on: July 13, 2009, 07:17:51 pm »
I'm guessing, REALLY guessing, you mean advanced duplicator?
Even if you're english isn't great..typing the full name of what you're having trouble with would help us.
As for advanced duplicator, I know there are settings for it in a config file I think.
It's been a long time since I've used it. Perhaps you should ask at the advanced duplicator thread on Facepunch.
We didn't write it, so I've moved this topic to Off-Topic for now.
Perhaps someone else can help you.
JackBauer
Re: Adv Problem
« Reply #2 on: July 13, 2009, 10:26:45 pm »
hmmmm yes my english is bad i am german :D.
I mean advanced duplicator , i have a problem:: anyone can spawn weapons,npc with advanced duplicator. you know?
he spawn weapons singeplayer then he uploade the files and spawn it.
Re: Adv Problem
« Reply #3 on: July 14, 2009, 07:31:38 pm »
I'm sorry. I do not know.
Maybe someone else here knows.
There is probably a configuration file that can be set to not allow uploads?
Maybe go read/search/ask in the Advanced duplicator thread at Facepunch, or maybe wiremod.com (I think the author of adv duplicator is a wiremod contributor, I'm not sure)
Re: Adv Problem
« Reply #4 on: July 14, 2009, 08:40:14 pm »
I looked into it, and the only thing I can recommend is URestrict. It will not stop the problem with players being able to spawn the weapons via Advanced Duplicator, but they will not be able to pickup/use the weapon if URestrict is configured not to. Perhaps this will deter them from spawning the weapons after a while.
Offline atomicspark
Re: Adv Problem
« Reply #5 on: August 08, 2009, 03:57:31 pm »
Disable Adv Duplicator uploads.
Yes to all. I forget the command to do so though. Searching wiremod.com would help.
