Author Topic: Where is the modules folder?  (Read 5712 times)
Offline Stephen304
« on: July 15, 2009, 03:58:57 pm »
I know this is a relatively easy question, but there are a lot of folders called modules.
I'm trying to add in my lua file of wire variables but after trying a couple module folders i can't seem to find the right one. Where is the folder i should use?
Re: Where is the modules folder?
« Reply #1 on: July 15, 2009, 04:43:06 pm »
ulx\lua\ulx\modules
Offline Stephen304
« Reply #2 on: July 15, 2009, 05:19:11 pm »
For some reason i see no difference in the menu before i placed the .lua file in there and after i placed the file there.
Is this correct?
ulx.addToMenu( ulx.ID_MADMIN, Max Wire Pods :, { max=100, cvar="sbox_maxwire_pods " } )
I have one of those for each variable i added with just the variable and the name changed from line to line. Is that how its supposed to be?
« Reply #3 on: July 15, 2009, 05:32:21 pm »
Off the top of my head, remove the space between pods and the quote, and you need "Max Wire Pods:" within quotes. Also, watch your console for errors. They'll help.
Offline Stephen304
« Reply #4 on: July 15, 2009, 06:53:06 pm »
Ok i tried that and now every lien in the lua file looks similar to this:
ulx.addToMenu( ulx.ID_MADMIN, Max Lights:, { max=100, cvar="sbox_maxlights" } )
And no errors in the server console or the client console. Nothing seems changed at all in the admin menu.
« Reply #5 on: July 15, 2009, 08:34:09 pm »
ulx.addToMenu( ulx.ID_MADMIN, "Name Of Slider", { max=100, cvar="actual name of convar" } )
« Last Edit: July 15, 2009, 08:35:51 pm by JamminR »
Offline Stephen304
« Reply #6 on: July 16, 2009, 10:46:18 am »
Whoops missed that.
Thanks now it works great and everything's in the menu.
« Reply #7 on: July 16, 2009, 12:18:26 pm »
Another way you can do this would be:
  1. Menu_Items = { "Max Wire Pods:" = "sbox_maxwire_pods", "Max Lights:" = "sbox_maxlights" }
  2. for title, command in pairs( Menu_Items ) do
  3.         ulx.addToMenu( ulx.ID_MADMIN, title, { max=100, cvar=command } )
  4. end
