Author Topic: Problems  (Read 8274 times)
Offline bennie900
Problems
« on: July 26, 2009, 01:42:03 pm »
Hi,
So I have a problem when I use a player name command for example:
"ulx adduser <name>" after the "adduser" and when I prace Space, the following error pops up
ULib/shared/util.lua:102: bad argument #1 to 'ipairs' (table expected, got nil)
and after that every time I type the characters of the name it comes up with the same error.
Also when I do the !menu and choose "Admin" this error pops up (some times):
ulx/modules/cl/adminmenu.lua:15: bad argument #1 to 'SetText' (string expected, got nil)
I then try and change the PvP Damage and all the other buttons but this error pops up:
nil)ulx/modules/cl/adminmenu.lua:48: bad argument #1 to 'SetText' (string expected, got nil)
Thanks for any help.
Re: Problems
« Reply #1 on: July 26, 2009, 01:47:38 pm »
This would be due to a recent change in SVN, going to look into it.
Offline bennie900
Re: Problems
« Reply #2 on: July 26, 2009, 01:49:10 pm »
I had it for a couple of days and thought you where aware of the problem but obvious not  :P
Re: Problems
« Reply #3 on: July 26, 2009, 02:50:05 pm »
Fixed in rev 34. Thanks for not only braving our SVN, but for reporting this issue. Have a cookie. :)
Edit: Well, I guess I should say the first issue is fixed. Going to see if I can see what's up with the menu.
Re: Problems
« Reply #4 on: July 26, 2009, 03:23:30 pm »
I spent some time looking over the code, trying to figure out where the menu error could be coming from, and turned up nothing. Since XGui is going to (hopefully) replace all our other menus, I'm not worry about it too much.
Re: Problems
« Reply #5 on: July 26, 2009, 05:10:26 pm »
Stickly man.. pay attention... the gauntlet has been placed into the wild... now you must run it. :D
Re: Problems
« Reply #6 on: July 26, 2009, 05:40:14 pm »
lol  ;) Don't worry-- the more and more I work on it, the better and better it gets! Its still gonna take me a bit though.. have lots of ideas planned haha
