Author Topic: Cvar when joining  (Read 6693 times)
Offline bennie900
Cvar when joining
« on: August 01, 2009, 04:23:47 am »
Hi, So when I join this pops up in the screen
You do not have access to this cvar, ({SM})SO.Bennie.
as I'm aware this happens to all players. I don't think this is causing any problems just thought I would make you aware of this.  I am running revision 38 SVN.
EDIT: I checked the console for any other errors but none i can see.
« Last Edit: August 01, 2009, 04:31:31 am by bennie900 »
Offline [WCA]AIDS
    • PlanetWCA Forums
Re: Cvar when joining
« Reply #1 on: August 01, 2009, 01:48:58 pm »
This is also present in Revision 39.
The message appears 3 times in red text when a player first spawns.
« Reply #2 on: August 01, 2009, 07:38:20 pm »
Odd, thought I fixed it back in revision 39. Will look into it again, thanks! :)
« Reply #3 on: August 03, 2009, 11:21:36 am »
[WCA]AIDS, does the message show in red or blue? If blue, it's from UPS and I'll be fixing that shortly. If red, it's from ULX and I'm unable to duplicate your problem, could you attach your server.ini file if this is the case?
EDIT: And now that should be fixed, too! The error is also a little more helpful now, in case you keep getting it.
« Last Edit: August 03, 2009, 11:34:26 am by Megiddo »
Offline atomicspark
« Reply #4 on: August 03, 2009, 02:18:33 pm »
I know for a fact that AIDS doesn't use UPS on his RPDM server (although he should).
I witnessed this error too, but ignored it as per the "SVN might break" warnings. I told AIDS to revert back to the main release, but he didn't listen. :(
« Reply #5 on: August 03, 2009, 02:32:12 pm »
Okay, hopefully he'll attach his server.ini file, then. Somebody's got to use SVN or we'll release with all the bugs still in there, atomicspark. :P
Offline [WCA]AIDS
    • PlanetWCA Forums
« Reply #6 on: August 03, 2009, 11:21:47 pm »
Sorry that I have not responded quicker.
The text is red, not blue. Sparks is correct when he says I do not use UPS (and no I shouldn't, the pp built into the game mode works perfectly fine)
Also,
The people who host my server are changing hosts and I do not have any back-ups of any ULX related files. This is the closest thing to the server.ini I was using that I can give you. This server.ini was included with Pre-Revision 34 ULX.
Also, rslotsmode was 0,
I forgot to change that when I archived the file just now.
« Last Edit: August 03, 2009, 11:35:23 pm by [WCA]AIDS »
Offline atomicspark
« Reply #7 on: August 04, 2009, 11:57:13 am »
I'm not currently getting any errors with the latest version. These are good things.
« Reply #8 on: August 18, 2009, 09:14:37 pm »
I was never able to get this message, but I added a few things that I thought might help. Let me know if you still get this message now.
