Author Topic: Map specific commands  (Read 4164 times)
Offline Otacon
« on: August 03, 2009, 06:13:40 am »
So I am trying to make map specific commands work in my server, but for some reason it really does not make a difference. I have a .ini file called sb_gooniverse.ini which has "sv_gamemode" "spacebuild3" inside it. shouldn't that be enough? Any help is greatly appreciated
Re: Map specific commands
« Reply #1 on: August 03, 2009, 09:08:42 am »
The gamemode is already set when the map-specific config loads, sorry.
« Reply #2 on: August 03, 2009, 02:57:13 pm »
Otacon, you can change to a gamemode/map manually. See ulx help for the map command
o map <map> [<gamemode>] - Changes the map and gamemode (if specified). (say:!map)
Offline Otacon
« Reply #3 on: August 03, 2009, 07:44:44 pm »
Yeah, I know about the manual command, I just wish it was automatic :P
