Author Topic: !menu = small empty box?  (Read 9565 times)
Offline Alex-Weazel
« on: August 05, 2009, 03:13:44 pm »
Hey all,
Just added ulx/ulib to my server and successfully added myself as superadmin however when typing in !menu the box that appears is at the bottom of my screen and has nothing in it!
Anyone else seen this before?
Better yet, anyone know how to fix it  :-\
Re: !menu = small empty box?
« Reply #1 on: August 05, 2009, 03:27:29 pm »
Alex, any errors in console?
Running any addon that _might_ adjust derma or chat windows?
Last time I saw similiar was right after a Gmod update.
Didn't affect my ULX menus, but affected all my actual spawn menus.
Offline Alex-Weazel
« Reply #2 on: August 05, 2009, 03:44:02 pm »
No console errors, only addon that i can think might do anything is the Sui Scoreboard?
« Reply #3 on: August 06, 2009, 06:20:01 pm »
Can you use any ULX commands?
Offline Alex-Weazel
« Reply #4 on: August 07, 2009, 12:41:42 pm »
It seems that I can't use commands either. "Sorry you dont have access to this yadda yadda yadda"
EDIT: And yet when joining I see this in console:
"[UCL] Access set.
Hey 'alex-weazel' - You're in the 'superadmin' group on this server."
« Last Edit: August 07, 2009, 12:50:00 pm by Alex-Weazel »
Offline Alex-Weazel
« Reply #5 on: August 07, 2009, 01:05:23 pm »
Ok sorry for doublepost but after removing SUI Scoreboard I now have the MOTD button under !menu but nothing else.
Also with the scoreboard now being the default style my Bar is green which I believe is the colour for admins?  :-\
« Reply #6 on: August 07, 2009, 03:32:05 pm »
Alex, please attach to your next post the file created from the "ulx debuginfo" command.
Run that from the server console while you are connected to it.
File gets created on the server.
It sounds as though Gmod itself sees you as a superadmin, but for an unknown reason, ULX or ULib is corrupt in giving access. Various reasons cause this.. the debug info may help us.
Offline Alex-Weazel
« Reply #7 on: August 08, 2009, 01:18:54 pm »
Ok, I couldn't run it myself ingame as it wouldn't let me, but I did run it from HLSW while I was still on the server. Dunno what difference that would make for you  :)
« Reply #8 on: August 08, 2009, 07:46:03 pm »
For some reason your inheritance chain isn't setup like it should be. The easiest way to fix it would be to remove data/ulib/groups.txt and let it regenerate at server restart.
Offline Alex-Weazel
« Reply #9 on: August 09, 2009, 04:40:15 am »
That's done the trick!
Thanks for the assistance and patience!
Offline ETTETT
« Reply #10 on: August 21, 2009, 04:22:33 pm »
I had this same problem before i deleted misc_registeredusers or what ever and groups.txt
