Author Topic: URequest  (Read 43561 times)
Re: URequest
« Reply #30 on: November 18, 2009, 10:12:49 pm »
Is there some exploit using SteamID's I'm not aware of?
     - Nah, I just wanted to play with some encryption for fun :P, but on second thought it really isn't necessary.
Offline Tom
Re: URequest
« Reply #31 on: November 19, 2009, 11:15:40 am »
well if it helps... I am a server owner and you guys probably are too but, I don't see the point in encrypting steam IDs. Also if you have them, I think it would be good to see them, so that you can use them to punish people misusing it? Just a thought.
Re: URequest
« Reply #32 on: November 19, 2009, 04:30:23 pm »
An update has been released, see first post! :D
Offline Tom
Re: URequest
« Reply #33 on: November 20, 2009, 11:59:01 am »
Looking good! I'm going to wait until the full release with chat commands and gui comes out before I download... But hope to see it soon!!
Tom.
Re: URequest
« Reply #34 on: November 20, 2009, 03:10:56 pm »
URequest is up an running with the full GUI and commands now. Enjoy!
Offline Tom
Re: URequest
« Reply #35 on: November 22, 2009, 04:53:26 am »
Mine is still not workring... when the server starts up:
Lua Error: ERROR: Hook 'URequest_Init' Failed: ULib/modules/URequest.lua:91: attempt to index field 'Accepted' (a nil value)
Lua Error: Removing Hook 'URequest_Init'
Re: URequest
« Reply #36 on: November 22, 2009, 06:37:41 am »
I honestly don't see how that is possible.
Offline Tom
Re: URequest
« Reply #37 on: November 22, 2009, 07:34:35 am »
I actualy have no idea what it means... so i cant really help in it ^^
Re: URequest
« Reply #38 on: November 22, 2009, 12:58:12 pm »
Did it ever work for you, or was it broken since install?
Offline Wayne Brady
Re: URequest
« Reply #39 on: November 22, 2009, 02:01:34 pm »
Does this work on the non svn version?
Re: URequest
« Reply #40 on: November 22, 2009, 04:35:11 pm »
No, requires the latest ULib svn
Offline Tom
Re: URequest
« Reply #41 on: November 22, 2009, 05:55:31 pm »
well before you rebuilt... i could bring up the gui.. but when i made a request nothing happened and none of the console commands worked.. and after rebuild absolutely nothing works.
Offline sharp
Re: URequest
« Reply #42 on: February 16, 2010, 06:51:36 pm »
i got an error in server startup there  seems to be a problem with ulx.addAdvert
ulx\modules/URequest_Advert.lua:1: attempt to call field 'addAdvert' (a nil value)
Edit: oh and this too
[ULIB] Loading SERVER module: URequest.lua
ULib/modules/server/URequest.lua:210: attempt to call field 'begin_subconcommand' (a nil value)
« Last Edit: February 16, 2010, 07:01:34 pm by sharp »
Re: URequest
« Reply #43 on: February 17, 2010, 10:50:06 am »
Looks like you have the old version, which will not work with the latest ULib/ulx. Please grab the new copy from the first post. That should fix your problems.
Offline Buggzie
Re: URequest
« Reply #44 on: June 13, 2010, 06:34:08 am »
can you make a mysql version so you can get suggestions from multiple servers instead of one and it displays the server name the suggestion was given from?
