Author Topic: Countdown  (Read 10584 times)
Offline iBurnPuppies
Countdown
« on: August 11, 2009, 11:19:13 am »
Citrus has a nice little countdown feature where you give it text, what time to countdown from, and if you want, it runs a command once it ends. ULX should get this. What it could be is that you type something like, !countdown "This is a test of the countdown!" 60 "ulx map gm_construct". In the top right corner, you see the text of the countdown, and below it, how much time is left, in this case 60 minutes, and then the command that's going to be run once the countdown ends.
Re: Countdown
« Reply #1 on: August 11, 2009, 06:35:23 pm »
Other than perhaps someone writing a 3rd party release for ULib, I don't see this being added to ULX.
It might be a fun feature, but it's not a requirement to administer a server.
Conna, as we know him, tried making Citrus so much more than an admin mod.
But then again, ULib is so much more than ULX..so, meh.
ULib, and the admin mod ULX that runs on ULib, is only meant to be an admin mod.
As for your example of changing a map... there is a release in our Releases section that does that.
/index.php/topic,688.0.html
Re: Countdown
« Reply #2 on: August 12, 2009, 01:21:14 am »
I understand. I forget that ULX is meant to be a simple tool to make administrating a server easier, not a way to cram in random features. Thanks for listening to my suggestion though, I appreciate it.
Re: Countdown
« Reply #3 on: August 12, 2009, 03:03:57 pm »
Your welcome.
We do occasionally throw in ideas that aren't really required to administer a server.
I mean, really, does administrating a server really require a 'maul' command?
No, but it sure does make a fun punishment, right?
Never be afraid of making suggestions.
Re: Countdown
« Reply #4 on: August 13, 2009, 02:52:11 pm »
Or maybe Megiddo just really wanted to do something in lua with NPCs. ;)
Offline benbrooks
Re: Countdown
« Reply #5 on: September 06, 2009, 04:14:49 am »
This countdown will start by typing in !countdown [seconds] and it will finish with a chat notification and a gunshot. It's quite customizable but not sure if this is what you want.
//Countdown script by Toneo
//:D
local AdminOnly = false //Who can start countdowns? Only admins can stop countdowns.
local EchoConsole = false //Echo into the console? (10,9,8,7,6,5,4,3,2,1,Endofcountdown etc)
local EchoChat = false //Echo into the chat?
local EchoCenter = true //Echo into middle of the screen?
local GunShot = true //Play a gunshot when the countdown is up?
local secondsRemaining = 0 //Don't edit this. It doesn't make any difference if you do :3
local function StartCountDown(ply,cmd,args)
if (AdminOnly) && !ply:IsAdmin() then return end
if !args[1] then Msg("Hey! Countdowns need a time! :(\n") end
//Protection against negative numbers (not sure what happens if we use them but ima blocking them)
if (tonumber(args[1])<=0) then
Msg("You can't have that delay!")
local function Tick()
if EchoConsole then MsgAll(secondsRemaining.."\n") end
if EchoCenter then
for k, v in ipairs(player.GetAll()) do
v:PrintMessage(HUD_PRINTCENTER,secondsRemaining)
if EchoChat then
for k,v in pairs(player.GetAll()) do
v:PrintMessage(HUD_PRINTTALK,secondsRemaining)
secondsRemaining = secondsRemaining - 1
local function End()
v:PrintMessage(HUD_PRINTTALK,"The countdown has ended.")
v:PrintMessage(HUD_PRINTCENTER,"The countdown has ended.")
if GunShot then
v:ConCommand("play weapons/357/357_fire2.wav")
secondsRemaining = tonumber(args[1])
timer.Create("CookieCountdown",tonumber(args[1])+2,1,End) //I dunno why I have to add 2 but if I don't it goes.. 60 59 58 ..etcetc.. 5 4 3 The Countdown has ended 2 1
timer.Create("CookieCountdownTICK",1,tonumber(args[1]),Tick)
v:PrintMessage(HUD_PRINTTALK,"Timer has been created by "..ply:Nick().." with a delay of "..tonumber(args[1])..".")
concommand.Add("countdown_start",StartCountDown)
local function CancelCountdown(ply,cmd,args)
if ply:IsAdmin() then
timer.Remove("CookieCountdown")
timer.Remove("CookieCountdownTICK")
v:PrintMessage(HUD_PRINTTALK,"The timer has been cancelled by "..ply:Nick().."!")
ply:PrintMessage(HUD_PRINTTALK,"You are not an admin!")
concommand.Add("countdown_cancel",CancelCountdown)
local function CountChatHook(ply,text)
local sep = string.Explode(" ",text)
if sep[1] == "!countdown" then
if !sep[2] then ply:PrintMessage(HUD_PRINTTALK,"You need to type the delay!") end
ply:ConCommand("countdown_start "..sep[2]) //Do it
return "" //Don't say anything :)
if sep[1] == "!cancelcountdown" then
ply:ConCommand("countdown_cancel") //Do it
return ""
//We are NOT returning at the end (otherwise we will override ALL OTHER CHAT COMMANDS)
hook.Add("PlayerSay","CountDownChat",CountChatHook)
Re: Countdown
« Reply #6 on: September 12, 2009, 10:24:21 pm »
It looks great, though I don't know how to install it. How do I install it?
Offline [WCA]AIDS
    • PlanetWCA Forums
Re: Countdown
« Reply #7 on: September 13, 2009, 12:54:00 am »
Copy and paste all of the code into notepad.
Save the file as <whateveryouwant>.lua
Place the file in your server's lua\autorun\server directory
restart your server or in rcon run 'lua_openscript lua\autorun\server\<whatevernameyouchose>.lua'
For example,
I will save the script as countdown.lua
lua_openscript lua\autorun\server\countdown.lua
tada, you can now !countdown.
Re: Countdown
« Reply #8 on: September 13, 2009, 04:40:15 am »
Ben, did you write that?
If not, do you know Toneo?
Offline benbrooks
Re: Countdown
« Reply #9 on: September 13, 2009, 10:58:02 am »
I know Toneo :)
Re: Countdown
« Reply #10 on: September 13, 2009, 12:43:57 pm »
Ok. Pass some words to him for me?
He could optimize the code much better if he were to use as little for/pairs loops as possible.
The Tick function would be better with only one.
Similiar to
For => pairs
if <chat indicator> then <blah>
if <center indicator> then <blah>
Rather than having two for pairs loops.
Though this script is small and it probably doesn't hurt much, larger scripts if he ever makes them, for pairs are actually pretty process costly.
