Author Topic: Tooldeny  (Read 4780 times)
JackBauer
Tooldeny
« on: August 24, 2009, 02:39:07 am »
Hi,
If i add ulx tooldeny dakara then is acess not allowed. But i restart and then i can use  dakara. Can you help? I use it now , urestrict suck
can you add this to ulx? tooldenygroup [<group>] <toolmode> - Denies a group to use of the specified toolmode.
sample:
User - Denies = ulx tooldenygroup user dynamit (the user cant use dynamit)
respected - allowed = respected can use this he is not add.....
zocker - allowed = zocker can use this he is not add....
« Last Edit: August 24, 2009, 07:44:18 am by JackBauer »
Re: Tooldeny
« Reply #1 on: August 24, 2009, 08:26:37 am »
Hi,
     - That is sad to hear, cause I really don't see a chance for you request to happen, and what abbout URestrict sucks. You need to elaborate a little bit more in order for us developers to make changes to make our scripts better. Currently the only thing wrong with "URestrict" is actually an error in ULib.
Quote from: JamminR
EC, you should really post your challenge with URestrict in the URestrict thread.
ULX has options for some tool control, but, they aren't based on group, only per user or per everyone (including admins), and thanks to the hard work Jay is putting into URestrict, we aren't going to be upgrading the ulx tool commands.
It wouldn't surprise me if we were to eventually remove them.
We (Team Ulysses) have been pointing everyone towards URestrict for the access you're wanting to control.
Jay's been working hard on a rewrite of the code base of URestrict...how long since you last used it, and, were you running all the latest SVN versions of ULib and URestrict?
I understand if  you don't want to run SVN (our beta code), but, it really is meant to do what you're trying to do.
JackBauer
Re: Tooldeny
« Reply #2 on: August 24, 2009, 10:26:10 am »
not only this bug. I have add to one stool respected,zocker,admin,superadmin. So no add to a other tool: admin,superadmin, i go back to my first add stool: no groups more all delete! FU
Re: Tooldeny
« Reply #3 on: August 24, 2009, 10:47:53 am »
     - See, that helps me alot more, I can get that fixed here really quick.
FU
     - That is not needed. This is a family friendly forum and we intend to keep it that way.
Offline atomicspark
Re: Tooldeny
« Reply #4 on: August 24, 2009, 08:40:09 pm »
Most ULX commands are not saved on server restart. There is a difference between a running configuration and saved configuration. For example if you want to always disable a tool, you'll have to add it to your server.ini or server.cfg file.
Re: Tooldeny
« Reply #5 on: August 25, 2009, 04:05:01 am »
Good thing about URestrict, everything is saved :D
