Author Topic: Stripguns  (Read 6382 times)
Offline Donkie
Stripguns
« on: September 05, 2009, 07:23:15 am »
Hello there folks!
New ulx function from me!
I dont know if this is already made but then its made again.
This function strips only the guns of the target. So you will still have the physgun, toolgun, gravgun and camera.
It also works in darkRP where it gives keys and that stuff. <-- Needs updating. (only works for jobs without any special sweps)
Paste at the end of the code in the ulx/lua/ulx/modules/fun.lua
function ulx.cc_stripguns( ply, command, argv, args )
if #argv < 1 then
ULib.tsay( ply, ulx.LOW_ARGS )
return
local targets, err = ULib.getUsers( argv[ 1 ], _, true, ply ) -- Enable keywords
if not targets then
ULib.tsay( ply, err )
return
for _, v in ipairs( targets ) do
ulx.logUserAct( ply, v, "#A stripped #T's guns." )
v:StripWeapons()
v:Give("weapon_physgun")
v:Give("weapon_physcannon")
v:Give("gmod_tool")
v:Give("gmod_camera")
if gamemode.Get("darkrp") == nil and gamemode.Get("Darkrp") == nil and gamemode.Get("DarkRp") == nil and gamemode.Get("DarkRP") == nil then
return
v:Give("keys")
if CfgVars["toolgun"] == 1 or v:HasPriv(ADMIN) or v:HasPriv(PTOOL) then
v:Give("gmod_tool")
if CfgVars["pocket"] == 1 then
v:Give("pocket")
if CfgVars["physgun"] == 1 or v:HasPriv(ADMIN) or v:HasPriv(PHYS) then
ulx.concommand( "stripguns", ulx.cc_stripguns, "<user(s)> - Strips user(s)'s guns, not physgun, toolgun, camera or gravgun. Also works with Darkrp!", ULib.ACCESS_ADMIN, "!stripguns", _, ulx.ID_PLAYER_HELP )
ulx.addToMenu( ulx.ID_MCLIENT, "Stripguns", "ulx stripguns" )
Untested but should work, command:
!stripguns <user(s)>
For using with darkrp, the darkrp gamemode folder needs to be named:
  • darkrp
  • Darkrp
  • DarkRp
  • DarkRP
kthxbai
