Author Topic: Broken Superadmin & Client Menu Help  (Read 6558 times)
Offline YoUrWoRsTnIgHtMaRe
« on: September 11, 2009, 09:00:13 pm »
Hy guys my super admin is broken. It says they are super admin but they don't have anything. The only way we can do anything through ulx rcon otherwise the menu doesn't work. Even after several retries and attempts.
Also I was wondering if there was a way to add a command in client menu for my admins and super admin. I'm trying to make several buttons that are like: Ban 1 Month; Ban 1 Week; Ban 1 Year
Is there anyway to do this? Please help and thanks!
Offline Major_Pain
Re: Broken Superadmin & Client Menu Help
« Reply #1 on: September 11, 2009, 09:11:57 pm »
Make sure when you edit the groups, you aren't editing them through the addons/ULib but editing them thorugh the data/ULib.
I suggest deleting your data/ULib/groups.txt and restarting your server. That should set all your superadmin and admin settings back to default.
« Reply #2 on: September 11, 2009, 09:20:59 pm »
It hasn't been an issue before, i've edited ulib groups a lot, its just recently started since recent updates
« Reply #3 on: September 11, 2009, 09:29:08 pm »
If you're using SVN, there's been a lot of error correction added lately, so if you had any problems in your file ULib would have fixed it by just removing the area you had an error in. The old ULib might've accepted this, but worked incorrectly.
« Reply #4 on: September 11, 2009, 09:33:33 pm »
yeah its svn... should I just wait about a week for you guys to fix it?
« Reply #5 on: September 11, 2009, 09:51:42 pm »
Sorry, I guess I wasn't clear. It is fixed. If you're having problems it's because you had the file formatted incorrectly.
« Reply #6 on: September 11, 2009, 10:13:25 pm »
Nightmare, you should really check your syntax and file editing.
In fact, I recently suggested you not manually edit due to your prone to manual entry mistakes
As Megiddo says.. manual editing is now much more sensitive to mistakes.
By all means I'm not saying our SVN is guaranteed to be perfect.
It's just difficult to lean towards our SVN being the issue and not having many other reports, and your tendency for editing errors.
