Author Topic: ULX ADMIN GROUPS LUA HALP!!!  (Read 16539 times)
Offline nofear1999
« on: September 14, 2009, 09:33:56 am »
does ULX Admin user groups function ply:IsUserGroup("group")
so ex. you can create a group called respected and
if ply:IsUserGroup("respected") then
code goes here
Re: ULX ADMIN GROUPS LUA HALP!!!
« Reply #1 on: September 14, 2009, 09:58:08 am »
I have no idea what you're talking about.
Offline nofear1999
« Reply #2 on: September 14, 2009, 11:36:14 am »
Ummm,
I was buzzed when I posted that.
Okay, ULX has function ulx addgroup
Does that function allow
function respectedcheck
ply:Give("phygun")
ply:Give("toolgun")
concommand.Add("respected", respectedcheck)
« Reply #3 on: September 14, 2009, 11:52:59 am »
IsUserGroup() is a garry function. It returns true if the user belongs to the group, yes. You might be looking for CheckGroup() though (see docs).
Offline nofear1999
« Reply #4 on: September 14, 2009, 12:51:35 pm »
I couldn'tfind CheckGroup in the Document.
Could you please link me?
Offline nofear1999
« Reply #6 on: September 14, 2009, 01:07:57 pm »
so
if ply:CheckGroup() == "Respected" then
ply:Give( "physgun" )
« Reply #7 on: September 14, 2009, 01:19:44 pm »
so
No. Pay attention to the docs. CheckGroup returns a bool and takes a parameter.
Offline nofear1999
« Reply #8 on: September 14, 2009, 01:49:59 pm »
I'm not experianced with Booleans yet,
Could you explain? I don't see any formats on the Documentation.
if ply:CheckGroup() "Respected" == 1 then
ply:Give( "toolgun" )
« Last Edit: September 14, 2009, 01:51:50 pm by nofear1999 »
« Reply #9 on: September 14, 2009, 02:15:33 pm »
This isn't the right place to start learning lua. Look to http://lua.org/pil and the garrysmod wiki until you got off your feet.
Offline nofear1999
« Reply #10 on: September 14, 2009, 02:17:07 pm »
I have, could you please explain the format to me?
I look @ Gmod wiki alot, i've gone through EVERY tutorial.
Please, explain it to me. :/l
« Reply #11 on: September 14, 2009, 02:36:43 pm »
CheckGroup("group")
Offline nofear1999
« Reply #12 on: September 14, 2009, 03:01:22 pm »
so
if ply:CheckGroup("respected") then
ply:Give("gmod_tool")
ply:Give("Physgun")
or
if CheckGroup("respected") then
ply:Give("Physgun")
« Reply #13 on: September 14, 2009, 04:02:32 pm »
Your first example should work.
Boolean basically means true or false.
Be careful though. CheckGroup will see inherited groups and return true.
For example, if admin inherits respected in the ULib UCL chain... admin's would get returned as true also.
If you only want the respected group to have something, then GetUserGroup is your best bet, and for that you would then use the example you showed already "if ply:GetUserGroup() == "respected" then"
« Last Edit: September 14, 2009, 04:08:17 pm by JamminR »
Offline nofear1999
« Reply #14 on: September 17, 2009, 11:22:24 am »
Thank you jamminR, i just went in like that and added  or == ("admin") or ("superadmin") then
