Author Topic: Cant change server name??  (Read 6493 times)
Hayden Fowler
« on: October 10, 2006, 06:44:52 am »
Okay. I downloaded the Dedicated server EXE file. I installed it and launched it at Steam/Tools/Dedicated server. I chose the name as Hayden's Server but when I go ingame, its called The newest Dedicated server out there! Can someone help me? What File do I have to change?
Re: Cant change server name??
« Reply #1 on: October 10, 2006, 09:05:42 am »
It's set in one of your configs. Check server.cfg.
« Reply #2 on: October 10, 2006, 06:42:32 pm »
Hayden,
 If you downloaded the dedicated server file from Facepunch, I believe you also have an OOOOLLLLD version of ULX.
However, before even going through how to use ULX, I suggest you learn server basics.
server.cfg is one major file you would need to edit.
I believe the server package released from FacePunch/garry.tv has a readme, with some basics on what needs to be changed there.
You should probably also learn how to set other configuration items.
Sorry, I don't have a good tutorial link. I suggest using Google.
I'm also moving this thread to Ulysses:General Chat, currently, its not ULib or ULX related.
