Author Topic: Anti-suicide plugin  (Read 27711 times)
Offline Vakaris
Re: Anti-suicide plugin
« Reply #15 on: September 26, 2009, 03:24:12 am »
Ok people, forget it. I found the problem - Player Possesor Swep. It caught my eye while I was looking at my mods and when I looked into it's lua\autorun\server\servercontrol.lua I found that that's what was overriding my script. Once I took it out it works perfectly again, now all that's missing is the fix on UClip and my server is back to it's former glory!  ;D
Edit: Maybe if I took the following out of the PPS it would work ok?
function FDoNotDieBitch(ply)
if table.HasValue(GlobalNoControlTable, ply:UserID()) then
return false
return true
hook.Add("CanPlayerSuicide", "FDoNotDieBitch",  FDoNotDieBitch)
Just tested it out, works perfectly.
« Last Edit: September 26, 2009, 03:35:50 am by Vakaris »
« Reply #16 on: September 26, 2009, 07:26:29 am »
You can fix PPS for it's author.
I thought the Author knew better. Fptje?
A script using a hook, should "NEVER" return true in a hook IF that hook is meant to continue and do nothing.
returning true in a standard gamemode hook breaks all other like hooks.
That's why your script isn't working with that in PPS.
You could fix it in two possible ways.
Remove the word "true" in the else statement.
Or
Remove the 'else' and 'return true' from the function totally.
ALso, I see that FTpje released that mod almost 2 years ago.
He's no longer supporting it at Facepunch.
I hope he's learned since then that returning true in a standard hook is usually a bad thing.
« Last Edit: September 26, 2009, 07:35:26 am by JamminR »
Offline atomicspark
« Reply #17 on: September 26, 2009, 10:12:39 am »
Gamemode.CanPlayerSuicide
Aha!
« Reply #18 on: September 26, 2009, 03:16:58 pm »
Yes Atomicspark, that's what we've been talking about since first post.
:P
Due to some mod badly using the hook, Vakaris' stopped working.
When you asked about a Garry's mod gamemode function existing, I didn't catch thats what you were looking for, since we'd already been discussing it.
Offline Vakaris
« Reply #19 on: September 26, 2009, 04:24:29 pm »
:P
I edited the mod by deleting the disallow suicide function from it. I was totally unecesary since in my server suicide is disabled by default.
I do beleave it's spelt " Vakaris's " not " Vakaris' ", since Vakaris is my name (Va-ka-ris the "s" is a part of my name) it does mean one person not multiple objects.
