Okay, I just tested downloading config files to a client via .res... It appears it's been blocked, yay!
Another way virii could spread is by making a menu in which you press a button to activate the virus. I'll go look into this.
Update:The above method is possible, but something similar to my "SendMenu" plugin could easily be used as the delivery system as well. Unfortunately, we can't trust users not to press a mysterious button in their spawn menu...
It's important to note that this would only be effective while running a listen server... but the button could easily be rigged to disconnect the user, start a listen server, and then run the virus command.
Anyone have ideas for a solution?
Another update:I informed garry of this exploit, waiting for a response. I've got to go to school for now, hope we can spawn some ideas to prevent this!
Yet another update:Here's the log from the chat with garry:
(10:33:10) (Megiddo) Garry, lua viruses aren't dead yet. You can still send exploitive commands in spawnmenus.
(10:33:52) (Megiddo) The server could give the client an ambigous file, give them a button on the spawn menu that would disconnect them from the current server, run a listen server, and execute that file.
(11:07:07) (garry) huh
(11:07:20) (garry) could that happen on any source game though
(12:42:42) (Megiddo) No, since it's using the spawn menu
(13:26:47) (garry) yeah but couldn't you use that meta mod thing to launch console commands on them
(13:28:12) (Megiddo) Good point. You could use a plugin to give them a virus and effectively run it.
(13:28:27) (Megiddo) I guess there's just no avoiding viruses then?
(13:28:35) (garry) I don't think you could
(13:28:47) (garry) else people would be doing it already
(13:29:15) (Megiddo) It was a lot easier with the previous methods
(13:29:46) (Megiddo) GM10 won't be able to write files outside of the gmod folder will it?
(13:29:59) (garry) won't be able to write outside the data/ folder
(13:30:25) (Megiddo) Ah, good.
(13:30:41) (Megiddo) Thanks for your time garry
Guess there's no hope of virus extermination? (By the way, this log stays private, don't let anyone else see it.)
