Author Topic: Real fall damage  (Read 17230 times)
Offline Dv2236
    • MyGamingVoid
Real fall damage
« on: October 12, 2009, 08:13:03 pm »
I was wondering if anyone knows how to make it so when you fall, you take damage base on how high you have fallen.
I hate this fall from 1000ft and only take 10 damage <_<
Re: Real fall damage
« Reply #1 on: October 12, 2009, 08:20:24 pm »
I believe it's sv_falldamage
Offline Dv2236
    • MyGamingVoid
« Reply #2 on: October 12, 2009, 09:09:46 pm »
I cant seem to get the command to work, said it was unknown, I did find a command called mp_falldamage but it dont seem to do anything for me.
« Reply #3 on: October 12, 2009, 09:56:52 pm »
Offline Dv2236
    • MyGamingVoid
« Reply #4 on: October 12, 2009, 10:20:22 pm »
I see now a getfalldamage amount has to be set, thanks jay, back when I last tried to look in google there was nothing.
][_, ([]) ][_, the 1 on fp was posted 2 days ago... time to give this another go.
« Reply #5 on: October 13, 2009, 05:25:15 am »
Ah yes, mp_falldamage. Guess Garry disabled it. :P
« Reply #6 on: October 13, 2009, 08:34:01 am »
     - Must of been a security fix haha :P
Offline atomicspark
« Reply #7 on: October 13, 2009, 05:42:47 pm »
mp_falldamage used to work. :(
Offline Dv2236
    • MyGamingVoid
« Reply #8 on: October 13, 2009, 05:57:40 pm »
I said I got it to work :S
setup the command mp_falldamage 1
and make a lua file in lua\autorun\server\GetFallDamage.lua
function MPFallDamage( ply, vel )
    if GetConVarNumber( "mp_falldamage" ) == 1 then
        vel = vel - 580
        return vel*(100/(1024-580))
hook.Add( "GetFallDamage", "MPFallDamage", MPFallDamage )
Than heat and serve. and you will have people lined up to fall and die, I mean what?
« Last Edit: October 13, 2009, 06:01:59 pm by Dv2236 »
« Reply #9 on: October 13, 2009, 08:15:50 pm »
gm_falleritus ... golden age gmod classics.
Offline raklatif
« Reply #10 on: October 26, 2009, 10:57:26 am »
 ;D ;D ;D Just so you know. there is an addon on garrysmod.org. here it is :D
http://www.garrysmod.org/downloads/?a=view&id=73018
You may use mp_falldamage as a scale for how much fall damage to take.
1 = take normal damage
0 = take no damage
0.5 take half damage
2 = bones are made of glass
0.025 You can fall from the highest building in gm_bigcity and still have more then 25 life...
