Author Topic: MOTD not working  (Read 7075 times)
Offline Joshieballz
MOTD not working
« on: October 24, 2009, 07:53:32 am »
hi all
i coded my motd and i put it in the folder "addons/ulx" but when i connect to my server it dosnt show up.
and when i type "!motd" it shows a different MOTD.
please help on what i have to do.
if u want to test my server the ip is: 83.170.117.5:27018
it is a spacebuild server
thanks
Joshieballz
Re: MOTD not working
« Reply #1 on: October 24, 2009, 08:39:25 am »
What version of ULX (release v# or latest SVN?)
What did you name the file?
It's been required to be "ulx_motd.txt" since ULX v3.4
Also, not positive about this one, try placing your ulx_motd.txt into your server gmod root folder.
/gmod/here
instead of /gmod/addons/ulx
Offline Joshieballz
« Reply #2 on: October 24, 2009, 11:03:53 am »
The version that is on the server is v3.1 because i was having problems with v3.4
« Reply #3 on: October 24, 2009, 12:37:36 pm »
Garry breaks his API so often I'd be surprised if 3.1 works at all anymore.
Offline Joshieballz
« Reply #4 on: October 24, 2009, 12:42:14 pm »
sorry i ment v3.31
Offline Joshieballz
« Reply #5 on: October 27, 2009, 10:31:40 am »
Still dosnt work :( :'(
« Reply #6 on: October 27, 2009, 03:12:30 pm »
motd.txt goes in gmod root. (Think that's it in 3.31)
ulx showMotd must be set to 1 (think it's that by default if you've never edited your ulx server.ini)
If you have edited ulx server.ini, make sure it's edited version resides in gmod/cfg
I believe Gmod now has a motd convar. I don't know what it is. It must be enabled too I'm pretty sure.
Also... why 3.31?
If you have problems with a new version... you really should ask for help.
New versions often include fixes to things Garry has broken, or fixes to known security risks.
Other than a ban file or user file issue when trying to work with players with \\ in thier names, 3.4 is solid.
Offline Joshieballz
« Reply #7 on: October 27, 2009, 05:15:36 pm »
ok i am running v3.4 now and when i put the ulx_motd.txt in the gmodroot folder and i type !motd ingame it dosnt work.
« Reply #8 on: October 27, 2009, 06:50:21 pm »
Does it show anything at all? Or just the default?
As for showing when you connect to your server, is your server.ini in gmod/cfg configured to show the motd?
Megiddo, our readme file isn't clear.. for 3.4...where does ulx_motd.txt go?
