AdvDupe_NoItems not work
Topic: AdvDupe_NoItems not work (Read 5979 times)
Speedpott
November 10, 2009, 06:55:47 am »
Hey,
I have run Wiremod,AdvDupe.... on my Server, default is AdvDupe_NoItems 1 then i cant spawn npcs,weapons. If run ULX,ULIB to AdvDupe_NoItems 1 but i can spawn npcs,weapons. Can anyone help?
Last Edit: November 11, 2009, 10:29:50 am by Speedpott
[WCA]AIDS
Jr. Member
Re: AdvDupe_NoItems not work
November 10, 2009, 01:18:07 pm »
Yes.
Speedpott
Reply #2 on:
November 11, 2009, 02:55:23 am »
yes what?
WildWill
Global Moderator
Full Member
Reply #3 on:
November 11, 2009, 09:46:09 am »
I've been out of the loop for a bit but I can tell you from that first post there that I doubt anyone is going to be able to decipher that. Might consider rewording that to get better help.
Speedpott
Reply #4 on:
November 11, 2009, 10:29:33 am »
I have run Wiremod,AdvDupe.... on my Server, default is AdvDupe_NoItems 1 then i cant spawn npcs,weapons. If run ULX,ULIB to AdvDupe_NoItems 1 but i can spawn npcs,weapons. Can anyone help me?
MrPresident
Ulysses Team Member
Reply #5 on:
November 11, 2009, 10:48:41 am »
not trying to sound rude... but your best bet is to find someone or a forum that is in your language and not try and get support on these forums using an online translator. The translation is horrible and it makes absolutely no sense! Sorry.
Speedpott
Reply #6 on:
November 11, 2009, 12:55:17 pm »
what? sorry but my main language is german and i can speak english littel bit.
my problem is:
I have run a Gameserver with Wire,WireExtras,Phx3,ULX,Utime.... and AdvDupe_NoItems is 1 (default). But is ulx running on this Server is it AdvDupe_NoItmes default but i not work.
JamminR
Ulysses Team Member
Sertafide Ulysses Jenius
Reply #7 on:
November 11, 2009, 03:31:32 pm »
We have no idea what wiremod_noitems does.
I do know that if it is part of WireExtras... the author of it often breaks other scripts, or writes it in a way that isn't compatible.
We've seen problems with WireExtras before ...
/index.php/topic,4299.0.html#msg16769 />
ULX, other than the Strip command, doesn't control weapons in any way.
It's not ULX.
ULX can control admin access to admin only tools/sweps... but again, if it works without whatever the wire_noitems switch is, but not without... it's the problem of the wire addon.
