Author Topic: Question regarding the '!' operator  (Read 5642 times)
Offline Doodle
« on: November 30, 2009, 02:52:32 am »
Hi All
Great admin plugin may I begin, however I was wonder is it possible to change the ! operator to something different say / instead?
I ask because I'm running both sourcemod and ULX, sourcemod for bans and kicks because it's synced with my clans sourcebans data base, ideally I'd like SM to run ! and ULX to run / so like /jail doodle etc.
I've looked through the config files can't seem to find anything suggesting you can change it..
Thanks All
Re: Question regarding the '!' operator
« Reply #1 on: November 30, 2009, 11:19:32 am »
Not easily, no. You'd have to modify each command you want changed. Try replacing all occurrences of "! with "/ -- that should do what you want.
Offline Doodle
« Reply #2 on: November 30, 2009, 11:26:16 am »
Sorry if this is glaringly obvious but how does one change each command to have / infront?
I though it might be misc_registered.txt file in the garrysmod/data/ulib folder but that lists all commands as 'ulx kick' for example not '!kick'...
thanks again for the help it's appreciated.
« Last Edit: November 30, 2009, 11:47:46 am by Doodle »
« Reply #3 on: November 30, 2009, 05:05:00 pm »
Scattered all over the ulx addon within the lua files.
