Author Topic: ULX Give - Give weapons to players.  (Read 116883 times)
Re: ULX Give - Give weapons to players.
« Reply #15 on: April 05, 2010, 10:50:55 am »
Welcome.
Syntax - a coder's worst nightmare
Offline Goldsun1715
« Reply #16 on: May 02, 2010, 06:51:56 pm »
Uh... so I've got the string right here:
local give = ulx.command( CATEGORY_NAME, "ulx give", ulx.give, "!give" )
What exactly am I supposed to set CATEGORY_NAME to?
« Reply #17 on: May 02, 2010, 08:42:49 pm »
Look at "ulx help" from console...it's categorized, I forget them off the top of my head, but it's like "Utility", "Player management", "punishment"... some like that.
Change CATEGORY_NAME to the "<category>" you want from the help menu. Enclose the name in quotes.
Offline Goldsun1715
« Reply #18 on: May 03, 2010, 02:09:11 pm »
Oh thank you very much. :)
Offline xynetor
« Reply #19 on: May 17, 2010, 05:04:49 am »
I don't know anything about LUA coding but this is the error I get.
ulx\modules/givesvn.lua:23: bad argument #1 to 'ipairs' (table expected, got nil)
« Reply #20 on: May 17, 2010, 04:21:26 pm »
Are you also getting the following error during server startup xynetor?
//  MODULE: givesvn.lua      //
ulx\sh_base.lua:182: table index is nil
If so, follow the instructions from the past few posts for editing CATEGORY_NAME
If not, when does that error occur?
Offline lavacano201014
« Reply #21 on: May 29, 2010, 03:09:12 pm »
You can also set whatever category you want in there - ULX seems to automatically adjust to it.
I have a "Madhouse" category for my server, and it works fine there.
Offline specter
« Reply #22 on: August 11, 2010, 11:21:09 am »
I am sorry but how can I make this script available to give a weapon to everyone on the serveR?
« Last Edit: August 11, 2010, 01:08:38 pm by specter »
« Reply #23 on: August 11, 2010, 05:29:50 pm »
Pheonix, Seth wrote this to allow ULX multiple player targeting.
Easiest way is to use * in svn, <all> in non-svn
Offline Blah
« Reply #24 on: March 21, 2012, 01:17:43 pm »
You do not have access to this command, Blah.
Does not seem to work anymore, I could use this :/
Offline skydive
« Reply #25 on: March 21, 2012, 01:22:05 pm »
Nice  8)
« Reply #26 on: March 21, 2012, 02:20:04 pm »
Hey Blah, Technically, it didn't work from first release, but the posts afterward explain how to fix it.
What access are  you on your server, and does it inherit admin?
Offline smithy285
« Reply #27 on: December 15, 2012, 03:24:05 am »
I am having the same problem to.
I am ULX admin and I have made myself admin in the server files as well (e.g userconfig and users.txt) and yet I still get the message that I don't have permission to access it. I am no good at coding and I don't know how to fix it. Any help would be appreciated.
« Reply #28 on: December 15, 2012, 05:01:37 pm »
Make sure you're trying the svn zip file.
You don't have to know how to code.
Open the only .lua file in a text editor.
Find where it says CATEGORY_NAME and change it to anything you want in quotes.
I recommend "Utility"
After doing that, if it doesn't work, then it's due to the fact this was released in December 2009.
There have been (virtually) countless number of updates to Gmod, ULX, and ULib since then.
Try PMing the original author, cause he's not been here since 2011, and would most likely not see any errors you post.
Offline Mesmaroth
« Reply #29 on: February 06, 2013, 10:01:36 pm »
Sorry for the bumb. But can someone try updating this? Don't want to use Fadmin for the weapons.
