Author Topic: Better "adding admins" system  (Read 6587 times)
Offline Syntax error
« on: December 04, 2009, 04:50:27 am »
OK listen, i have had my admin hacked 3 times today in 5 hours, so i have a suggestion to reduce hacks
When you use ulx add user admin/superadmin etc it straight away makes them an admin example
ulx adduser bob admin/superadmin 0/1                 Bob instantly gets admin or super admin with or without immunity
the idea i am thinking of is instead of making them admin instantly, why not make the ulx adduser command write the user info on a separate text file so then the owner has to add the user this will prevent hacks
example:
ulx adduser bob admin/super admin 0/1                Bob wont get admin until the owner puts the user info into the users text file
user info being:
"Bob"
   "deny"
   "type"   "steamid"
   "groups"
      "superadmin"
   "id"   "STEAM_0:1:12345678"
   "pass"   ""
   "allow"
      "immunity"
Re: Better "adding admins" system
« Reply #1 on: December 04, 2009, 08:48:13 am »
People think the user adding system is complicated enough already, we simply can't add another step to the process.
« Reply #2 on: December 04, 2009, 10:06:25 am »
Sorry if I am out of line here... but I don't believe there is a way to "hack" ULX. If you have some other server scripting (like a gamemode) that has some poorly coded admin functions a talented user/knowledged user could use it to backdoor add themselves as an admin...
What other major mods are you running? If you say DarkRP I'm going to e-slap you. =)
« Reply #3 on: December 04, 2009, 03:22:56 pm »
Syntax error, besides agreeing with both what Megiddo and MrPresident said, you could remove adduser from the code, and instead use Gmod's /settings/users.txt, like we recommend in the readme file that comes with ULX.
