Author Topic: Hidden Admin Commands  (Read 19529 times)
Offline CTO_7
« on: December 15, 2009, 08:38:38 pm »
In previous ULX versions, when an admin did a console command such as  ghost or cexec, the echo was only shown to the other admins. Now nearly every ULX command is echoed to all players on the server. I am requesting the option to make certain chat commands [and their echoes] visible only by admins.
Re: Hidden Admin Commands
« Reply #1 on: December 15, 2009, 08:50:02 pm »
This isn't a change in design, it's only a side effect of ULX SVN.
The server.ini settings for ULX SVN have not been converted yet.
(Rslots, logecho, maplist, etc)
Offline cammyd2
« Reply #2 on: February 22, 2010, 12:46:57 am »
Is there a way we could edit the files to make the echoes only visible to admins?
« Reply #3 on: February 22, 2010, 03:33:37 pm »
SVN server.ini, which you should copy from gmod\addons\ulx\cfg to gmod\cfg, has this.
ulx logEcho 1 // Echo mode
// Echo modes:
// 0 - OFF No output to players when an admin command is used
// 1 - FULL Output to players similar to "Foo slapped Bob with 0 damage"
I presume that which is enabled by default if you've not placed a copy in your gmod/cfg folder, will work.
Also, I'm not sure chat commands will be ever hidden again due to this.
/index.php/topic,4544.0.html#msg18314 />
I could be wrong.
