Author Topic: UTeam and Sui scoreboard...  (Read 18312 times)
Re: UTeam and Sui scoreboard...
« Reply #15 on: December 27, 2009, 01:00:16 pm »
sv_download url... aka Fast download... are you using it?
Do you host your files on an http server that players download from instead of downloading files from your Source server?
« Reply #16 on: December 27, 2009, 02:31:51 pm »
Whats that....?
we are just using the normal ulx motd.
Type 'sv_downloadurl' in server console without the quotes and paste the result here.
Offline Tommo1590
« Reply #17 on: December 28, 2009, 08:40:52 am »
Yea sorry we do use a sv_download url and it says this when i put that in console -
"sv_downloadurl" = "http://www.zip.uk.com/redirect/89.238.160.10:27021/orangebox/garrysmod/" ( def. "" )
 replicated
 - Location from which clients can download missing files
« Reply #18 on: December 28, 2009, 09:00:57 am »
You must add the lua cache to the download url, see here: http://wiki.garrysmod.com/?title=Setting_up_sv_downloadurl#The_Cache
Offline Tommo1590
« Reply #19 on: December 28, 2009, 09:59:26 am »
Can someone explain how to do this that link didnt really help me much :S
Thanks
« Reply #20 on: December 28, 2009, 03:08:25 pm »
Translation, make sure to copy the server's cache folder to the http folders, just like you do your maps, materials, anything else you store on the http server for your clients.
Update/re-upload the cache folder every time you make changes to your server's lua or addons folder.
Also, that sv_downloadurl seems to not be working but I'm not directly aware of how it secures it's redirection
« Last Edit: December 28, 2009, 03:15:33 pm by JamminR »
« Reply #21 on: December 28, 2009, 08:51:52 pm »
Also as a side note, only upload the cache from the server after a map change (when the cache is regenerated).
« Reply #22 on: December 28, 2009, 09:04:31 pm »
Oops. Meant to include that tip as part of my 'after every change bit'
Offline Tommo1590
« Reply #23 on: December 29, 2009, 08:10:43 am »
My host says the link for the fast download should be a 404 error, the way they have set it up blocks you from accessing it in a browser.
Also they said everything which is requested by the client on connect is auto uploaded from the server addons folder to the fast download auto.
...still got a problem with the teams though...  :(
