Author Topic: Adding ADMINS  (Read 7327 times)
Kyle
Adding ADMINS
« on: October 23, 2006, 04:04:37 pm »
ok so i have my access flags and all that mumbo jumbo but i do not know where to put this?
"MoofinMan" "" "abcdefghijklmn" "e"
is it in the configuration in the Ulib folder or what?
Re: Adding ADMINS
« Reply #1 on: October 23, 2006, 04:31:56 pm »
On a new line in users.ini
Kyle
Re: Adding ADMINS
« Reply #2 on: October 23, 2006, 04:36:47 pm »
i dont see any .ini but is it like the little note pad with the circular gadget thingy on the top?in the ulib folder right?
Re: Adding ADMINS
« Reply #3 on: October 23, 2006, 04:56:41 pm »
*sigh* Probably.
If you right click the file, select Properties from the menu, and its full name is users.ini , then yes, thats what you add to that file, and it should open in windows notepad
Kyle
Re: Adding ADMINS
« Reply #4 on: October 23, 2006, 05:07:05 pm »
thanks, also whenever  I have an explosion with a grenade or explosive it makes a black square on the ground?
Re: Adding ADMINS
« Reply #5 on: October 23, 2006, 06:07:27 pm »
That's a texture problem and has nothing to do with ULX or this thread. :P
Re: Adding ADMINS
« Reply #6 on: October 25, 2006, 03:51:22 pm »
Definitely a video driver issue, or the card just can't handle whatever settings you are using.
