Author Topic: Menu Error  (Read 4992 times)
s0ber
Menu Error
« on: October 24, 2006, 04:39:53 pm »
Running ULX2.1, Ulib1.1, Wanted to have Music mod in this menu also. AND is it normal for the "Changelevel" and "Misc ULX" menus to be in the "q menu"?
Lua Error: Line 40: attempt to call global 'ULX_CONCOMMAND' (a nil value)
LUA: Errors when running script 'ulx/menus.lua'
s0ber
Re: Menu Error
« Reply #1 on: October 24, 2006, 04:41:38 pm »
This is my menu script
--Main Menu--
ID_CLIENTMENU = 1
ID_ADMINMENU = 2
ID_MAPSMENU = 3
ID_WEAPONSMENU = 4
function cc_ulxMenu( userid, args )
beginMenu( userid, "ULX Main Menu", cc_ulxMenuFinal )
addOption( userid, "Client Menu", ID_CLIENTMENU, ACCESS_SLAY )
addOption( userid, "Admin Menu", ID_ADMINMENU, ACCESS_CVAR )
addOption( userid, "Maps Menu", ID_MAPSMENU, ACCESS_MAP )
addOption( userid, "Weapons Menu", ID_WEAPONSMENU, ACCESS_KICK )
addOption( userid, "Client Limits", ID_CLIENTLIMITS, ACCESS_CVAR )
addOption( userid, "Other", ID_OTHER, ACCESS_CVAR )
endMenu( userid )
function cc_ulxMenuFinal( userid, choice, seconds )
if choice == ID_EXIT then
return
elseif choice == ID_CLIENTMENU then
cc_ulxClientMenu( userid )
elseif choice == ID_ADMINMENU then
cc_ulxAdminMenu( userid )
elseif choice == ID_MAPSMENU then
cc_ulxMapsMenu( userid )
elseif choice == ID_WEAPONSMENU then
cc_ulxWeaponsMenu( userid )
elseif choice == ID_CLIENTLIMITS then
cc_ulxClientLimits( userid )
elseif choice == ID_OTHER then
cc_ulxOther( userid )
[b]ULX_CONCOMMAND( "ulx_menu", cc_ulxMenu, _, "- Shows the ULX main menu", 0, "menu", false )[/b]
--Admin Menu--
function cc_ulxAdminMenu( userid, args )
beginMenu( userid, "ULX Admin Menu", cc_ulxAdminMenuFinal )
--Add
_EntEmitSound(userid,"ambient/alarms/klaxon1.wav")
--End add
if _GetConVar_Bool( "sv_cheats" ) then
addOption( userid, "Cheats Off", "sv_cheats 0", ACCESS_CVAR )
addOption( userid, "Cheats On", "sv_cheats 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_playerdamage" ) then
addOption( userid, "Player Damage Off", "gm_sv_playerdamage 0", ACCESS_CVAR )
addOption( userid, "Player Damage On", "gm_sv_playerdamage 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_pvpdamage" ) then
addOption( userid, "PvP Damage Off", "gm_sv_pvpdamage 0", ACCESS_CVAR )
addOption( userid, "PvP Damage On", "gm_sv_pvpdamage 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_teamdamage" ) then
addOption( userid, "Team Damage Off", "gm_sv_teamdamage 0", ACCESS_CVAR )
addOption( userid, "Team Damage On", "gm_sv_teamdamage 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allowspawning" ) then
addOption( userid, "Disallow Spawning", "gm_sv_allowspawning 0", ACCESS_CVAR )
addOption( userid, "Allow Spawning", "gm_sv_allowspawning 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allowmultigun" ) then
addOption( userid, "Disallow Multigun", "gm_sv_allowmultigun 0", ACCESS_CVAR )
addOption( userid, "Allow Multigun", "gm_sv_allowmultigun 1", ACCESS_CVAR )
-- key 7 doesn't work
if _GetConVar_Bool( "say 7" ) then
addOption( userid, "Key 7 doesnt work", "say 7", ACCESS_CVAR )
addOption( userid, "Key 7 doesnt work", "say key 7 is not working in Gmod+!", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allowphysgun" ) then
addOption( userid, "Disallow Physgun", "gm_sv_allowphysgun 0", ACCESS_CVAR )
addOption( userid, "Allow Physgun", "gm_sv_allowphysgun 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allweapons" ) then
addOption( userid, "All Weapons Off", "gm_sv_allweapons 0", ACCESS_CVAR )
addOption( userid, "All Weapons On", "gm_sv_allweapons 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allowignite" ) then
addOption( userid, "Disallow Ignite", "gm_sv_allowignite 0", ACCESS_CVAR )
addOption( userid, "Allow Ignite", "gm_sv_allowignite 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_noclip" ) then
addOption( userid, "Disallow Noclip", "gm_sv_noclip 0", ACCESS_CVAR )
addOption( userid, "Allow Noclip", "gm_sv_noclip 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allownpc" ) then
addOption( userid, "Disallow NPC Spawning", "gm_sv_allownpc 0", ACCESS_CVAR )
addOption( userid, "Allow NPC Spawning", "gm_sv_allownpc 1", ACCESS_CVAR )
if _GetConVar_Bool( "gm_sv_allowlamps" ) then
addOption( userid, "Disallow Lamps", "gm_sv_allowlamps 0", ACCESS_CVAR )
addOption( userid, "Allow Lamps", "gm_sv_allowlamps 1", ACCESS_CVAR )
if _GetConVar_Bool( "sv_gravity" ) then
endMenu( userid )
function cc_ulxAdminMenuFinal( userid, choice, seconds )
return
_ServerCommand( choice .. ";gm_sv_setrules\n" )
AddTimer( 0.25, 1, cc_ulxAdminMenu, userid ) -- Give the server some time to register the command before rebuilding menu
ULX_CONCOMMAND( "ulx_adminmenu", cc_ulxAdminMenu, ACCESS_CVAR, "- Shows the ULX admin menu", 0, "adminmenu", false )
--Client Menu--
user_choice = {}
ID_SLAP = 1
ID_SLAY = 2
ID_SSLAY = 3
ID_FREEZE = 4
ID_UNFREEZE = 5
ID_GOD = 6
ID_EMPTY = 7
ID_UNGOD = 8
ID_IGNITE = 9
ID_KICK = 10
ID_KICKBAN = 11
ID_TEAM_RED = 12
ID_TEAM_GREEN = 13
ID_TEAM_BLUE = 14
ID_TEAM_YELLOW = 15
ID_GIMP = 16
ID_UNGIMP = 17
function cc_ulxClientMenu( userid, args )
menu_sendPlayersMenu( userid, cc_ulxClientMenuPart2 )
function cc_ulxClientMenuPart2( userid, target, seconds )
if target == ID_EXIT then
return
user_choice[ userid ] = target
beginMenu( userid, "ULX Command", cc_ulxClientMenuFinal )
addOption( userid, "Slap Player", ID_SLAP, ACCESS_SLAY )
addOption( userid, "Slay Player", ID_SLAY, ACCESS_SLAY )
addOption( userid, "SSlay Player", ID_SSLAY, ACCESS_SLAY )
addOption( userid, "Kick Player", ID_KICK, ACCESS_KICK )
addOption( userid, "Kickban Player", ID_KICKBAN, ACCESS_BAN )
addOption( userid, "Key 7 doesnt work", ID_EMPTY, ACCESS_SLAY )
addOption( userid, "Give Godmode", ID_GOD, ACCESS_SLAY )
addOption( userid, "Remove Godmode", ID_UNGOD, ACCESS_SLAY )
addOption( userid, "Freeze Player", ID_FREEZE, ACCESS_SLAY )
addOption( userid, "Unfreeze Player", ID_UNFREEZE, ACCESS_SLAY )
addOption( userid, "Ignite Player", ID_IGNITE, ACCESS_SLAY )
addOption( userid, "Force Team Red", ID_TEAM_RED, ACCESS_SLAY )
addOption( userid, "Force Team Blue", ID_TEAM_BLUE, ACCESS_SLAY )
addOption( userid, "Force Team Green", ID_TEAM_GREEN, ACCESS_SLAY )
addOption( userid, "Force Team Yellow", ID_TEAM_YELLOW, ACCESS_SLAY )
addOption( userid, "Gimp", ID_GIMP, ACCESS_SLAY )
addOption( userid, "Ungimp", ID_UNGIMP, ACCESS_SLAY )
endMenu( userid )
function cc_ulxClientMenuFinal( userid, choice, seconds )
local target = user_choice[ userid ]
if target == nil or _PlayerInfo( target, "connected" ) == false then
return
if choice == ID_EXIT then -- This is a global for when they hit the exit button, just take them back
cc_ulxClientMenu( userid, _ )
return
elseif choice == ID_SLAP then
ulx_slap( target, 0, 1000 )
elseif choice == ID_SLAY then
_PlayerKill( target )
elseif choice == ID_SSLAY then
_PlayerSilentKill( target, 3, true )
elseif choice == ID_GOD then
_PlayerGod( target, true )
elseif choice == ID_EMPTY then
_Screentext(0, 'Key 7 doenst work in Gmod+!', -1, -1, 255, 0, 0, 60, 2, 2, 10, 0, 0)
elseif choice == ID_UNGOD then
_PlayerGod( target, false )
elseif choice == ID_FREEZE then
_PlayerFreeze( target, true )
elseif choice == ID_UNFREEZE then
_PlayerFreeze( target, false )
elseif choice == ID_IGNITE then
_PlayerSetHealth( target, 139 ) -- This is so the person doesn't keep dying in the next spawn
_EntFire( target, "ignite", 1, 0 )
elseif choice == ID_KICK then
_ServerCommand( "kickid " .. _PlayerInfo( target, "networkid" ) .. "\n" )
elseif choice == ID_KICKBAN then
_ServerCommand( "banid 0 " .. _PlayerInfo( target, "networkid" ) .. " kick\n" )
elseif choice == ID_TEAM_RED then
_PlayerChangeTeam( target, TEAM_RED )
_PlayerRespawn( target )
elseif choice == ID_TEAM_GREEN then
_PlayerChangeTeam( target, TEAM_GREEN )
elseif choice == ID_TEAM_BLUE then
_PlayerChangeTeam( target, TEAM_BLUE )
elseif choice == ID_TEAM_YELLOW then
_PlayerChangeTeam( target, TEAM_YELLOW )
elseif choice == ID_GIMP then
ulx_gimp( _PlayerInfo( target, "networkid" ) )
elseif choice == ID_UNGIMP then
ulx_ungimp( _PlayerInfo( target, "networkid" ) )
function testCallBack( userid, unique_num, seconds )
ulx_tsay_all( _PlayerInfo( userid, "name" ) .. " choose menu ID #" .. unique_num .. "!" )
ULX_CONCOMMAND( "ulx_clientmenu", cc_ulxClientMenu, ACCESS_SLAY, "- Shows the client admin menu", 0, "clientmenu", false )
--Maps Menu--
function cc_ulxMapsMenu( userid, args )
local maps = getFilesFromDir( "maps/" )
beginMenu( userid, "Maps Menu", cc_ulxMapsMenuCallback )
for i=1, table.getn( maps ) do
if string.sub( maps[ i ], -4 ) == ".bsp" and string.sub( maps[ i ], 1, 10 ) ~= "background" and string.sub( maps[ i ], 1, 5 ) ~= "test_" then -- Ignore background maps
addOption( userid, stripExt( maps[ i ] ), stripExt( maps[ i ] ), ACCESS_MAP )
endMenu( userid )
function cc_ulxMapsMenuCallback( userid, map )
if map == ID_EXIT then
return
ulx_tsay_all( "CHANGELEVEL: " .. map )
AddTimer( 5, 1, _ServerCommand, "changelevel " .. map .. "\n" )
ULX_CONCOMMAND( "ulx_mapmenu", cc_ulxMapsMenu, ACCESS_MAP, "- Shows the map menu", 0, "mapmenu", false )
--Weapons Menu--
gIgnoreWeapons = {}
user_choice = {}
function cc_ulxWeaponsMenu( userid, args )
local weapons = getFilesFromDirRecursive( "lua/weapons" )
beginMenu( userid, "Weapons Menu", cc_ulxWeaponsMenuCallback )
for i=1, table.getn( weapons ) do
weapons[ i ] = string.sub( weapons[ i ], 5 ) -- The sub removes 'lua/'
if string.sub( weapons[ i ], -4 ) == ".lua" and gIgnoreWeapons[ weapons[ i ] ] == nil then
local weapon = getWeaponInfo( weapons[ i ] )
if weapon ~= nil and weapon.printName ~= nil then
addOption( userid, weapon.printName, weapons[ i ], ACCESS_KICK )
endMenu( userid )
function cc_ulxWeaponsMenuCallback( userid, weapon )
if weapon == ID_EXIT then
return
user_choice[ userid ] = weapon
menu_sendPlayersMenu( userid, cc_ulxWeaponsMenuFinal, _, "Give to:", true )
function cc_ulxWeaponsMenuFinal( userid, target )
return
if target == 0 then
for i=1, _MaxPlayers() do
debug( target .. " " .. i )
if _PlayerInfo( i, "connected" ) == true then
_PlayerGiveSWEP( i, user_choice[ userid ] )
_PlayerGiveSWEP( target, user_choice[ userid ] )
function addWeaponIgnore( weapon )
gIgnoreWeapons[ weapon ] = true
function getWeaponInfo( weapon ) -- TODO: Finish this function
if _file.Exists( "lua/" .. weapon ) == false or _file.IsDir( "lua/" .. weapon ) == true then
error_msg( "loadWeaponInfo given an invalid file!" )
return
_OpenScript( weapon )
local info = {}
info.printName = getPrintName()
info.classname = getClassName()
info.swapHands = getWeaponSwapHands()
info.fov = getWeaponFOV()
info.weaponSlot = getWeaponSlot()
info.weaponSlotPos = getWeaponSlotPos()
info.firesUnderwater = getFiresUnderwater()
info.reloadsSingly = getReloadsSingly()
info.damage = getDamage()
info.primaryShotDelay = getPrimaryShotDelay()
info.secondaryShotDelay = getSecondaryShotDelay()
info.primaryIsAutomatic = getPrimaryIsAutomatic()
return info
-- This ignore list in part is taken from andyvincent's weapon menu, you can check it out at http://forums.facepunchstudios.com/showthread.php?t=67193
addWeaponIgnore( "weapons/base.lua" )
addWeaponIgnore( "weapons/build/weapon_cratemaker.lua" )
addWeaponIgnore( "weapons/build/weapon_propmaker.lua" )
addWeaponIgnore( "weapons/build/weapon_freeze.lua" )
addWeaponIgnore( "weapons/build/weapon_remover.lua" )
addWeaponIgnore( "weapons/build/weapon_spawn.lua" )
addWeaponIgnore( "weapons/football/weapon_phys.lua" )
addWeaponIgnore( "weapons/hideandseek/weapon_catcher.lua" )
ULX_CONCOMMAND( "ulx_weaponmenu", cc_ulxWeaponsMenu, ACCESS_KICK, "- Shows the weapons menu", 0, "weaponmenu", false )
Re: Menu Error
« Reply #2 on: October 24, 2006, 09:15:32 pm »
That menu was made for ULX v1.1, sorry. Yes it's normal to have those things in your prop menu.
