Author Topic: Lots of unhandled usermessages  (Read 10074 times)
Offline jcsawyer
« on: January 23, 2010, 10:47:54 am »
Hi, i'm very new to gmod and running a server. I've tried installing the ULX mod with not 100% success.
When I first connect to my server, this is what I can see in the console:
ConVarRef ulx_welcomemessage doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_welcomemessage set to Welcome to %host%! We're playing %curmap%.), skipping
ConVarRef ulx_chattime doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_chattime set to 0), skipping
ConVarRef ulx_votemapSuccessratio doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_votemapSuccessratio set to 0.4), skipping
ConVarRef ulx_logEcho doesn't point to an existing ConVar
SetConVar: No such cvar ( ulx_logEcho set to 1), skipping
No pure server whitelist. sv_pure = 0
Lua initialized (Lua 5.1)
Sending 267 'User Info' ConVars to server (cl_spewuserinfoconvars to see)
Hey 'joseph?sawyer' - You're in the 'superadmin' group on this server.
Welcome to Garry's Mod! We're playing gm_construct.
Warning: Unhandled usermessage 'ulx_initplayer'
Warning: Unhandled usermessage 'ulx_addMenuItem'
Warning: Unhandled usermessage 'DSStart'
Warning: Unhandled usermessage 'DSPacket'
Warning: Unhandled usermessage 'DSEnd'
Redownloading all lightmaps
When I run my server I am able to use commands such as '!blind <name>' and '!unblind <name>'. When I try and do other commands though, these are some of the messages I get in the console:
Warning: Unhandled usermessage 'tsayc'
Warning: Unhandled usermessage 'ulib_sound'
I have no other MODS currently on the server. I would really like to get everything working!
Thanks in advance!
Re: Lots of unhandled usermessages
« Reply #1 on: January 23, 2010, 11:25:08 am »
What version of ULib, and what version of uLX? (Release or SVN?)
Looks as though your client connections aren't getting the required files for ULX from the server.
Are you using a dedicated server? Was it totally restarted (not just a map change, addon installs require shutdown/restart) after ULib and ULX were installed?
Using sv_downloadurl? If so, did you upload the server's cache folder to your host (again, after the gmod server was restarted)?
Offline jcsawyer
« Reply #2 on: January 23, 2010, 11:40:27 am »
1. How do I find out which version? I use SVN today so I assume that's the latest version...
2. Yes, I am using a dedicated server, and yes I completely restarted it.
3. I have sv_downloadurl "" in my autoexec.cfg file. Is that what I'm meant to have to not use it?
~EDIT~
I've just noticed a version.txt file and it says I have 2.4
« Last Edit: January 23, 2010, 12:11:54 pm by jcsawyer »
Offline jcsawyer
« Reply #3 on: January 23, 2010, 12:29:04 pm »
I've also just noticed that when I join the server it says there's some lua files that need downloading. However, it doesn't show it downloading them like it does other servers. Could this be the problem?
« Reply #4 on: January 23, 2010, 12:37:49 pm »
Absolutely. ULX has several key client side files that are required.
The server has ways to set size/what files it can send, and the client itself has ways to block files.
I don't have time at the moment to look them up.. try Google gmod maxfile and gmod download filter
Offline jcsawyer
« Reply #5 on: January 23, 2010, 03:48:30 pm »
I've Googled it and since I'm not 100% sure about what you're saying I have been unsuccessful with my results  ???
« Reply #6 on: January 23, 2010, 06:00:52 pm »
Two good server side cfg items to research.
sv_allowdownload
net_maxfilesize
As for client, I can't remember the terms.. can't find any after searching for 5 minutes.
You would have had to specifically set them to avoid downloads though.
They're mostly handy to set to keep from getting tons of mp3/wave files some Source servers like to host and send you.
Another item you can check, make sure the Windows user profile you are running your game as has write access to <x:\><your Steam gmod path>\cache
Offline jcsawyer
« Reply #7 on: January 24, 2010, 04:05:26 am »
I think this problem is fixed.
Basically, I completely deleted the orangebox folder on the server, re-ran HldsUpdateTool.exe with my parameters and the first thing I did was install the mod using SVN. So far, I've only been on once and it ran fine!
(running without a autoexec/server.cfg) I will try putting in a config later and test again.
« Reply #8 on: January 24, 2010, 03:40:57 pm »
One of the server cfg items must have been set to not allow any downloads at all.
Configs can be good for optimization, but sometimes you need to know what they're doing. Since you're not using an sv_downloadurl, you should learn how to control allowing lua files, but not large files (maps/materials, etc) that will take forever to download, and cause lag for your currently connected players.
