Author Topic: ULX unknown command  (Read 7485 times)
Offline vader0146
ULX unknown command
« on: January 25, 2010, 01:42:00 pm »
] ulx slap
Unknown Command: 'ulx'
Warning: Unhandled usermessage 'ups_ownerinfo'
Re: ULX unknown command
« Reply #1 on: January 26, 2010, 11:04:49 am »
Split this from another topic since it's another problem than the original thread entirely.
Do you have ULX installed, and are there errors on startup? Is this SVN?
Offline vader0146
« Reply #2 on: January 26, 2010, 12:46:59 pm »
Same problem as DiscoBiscuit, ULX and UPS goes down for no reason.
which is why I posted it in his thread.
« Reply #3 on: January 26, 2010, 04:27:37 pm »
Same end result, different symptoms... which from the code side means that the problems are not related.
« Reply #4 on: January 26, 2010, 05:42:39 pm »
Vader, your getting feedback from Gmod that "ulx" is an unknown command.
Discobiscuit, on the other hand, does not. He types in "ulx <something>", and gets dead air.
Though they do seem 'same', they are only similiar at this point that they occur, according to you, after time has passed.
Offline vader0146
« Reply #5 on: January 27, 2010, 08:49:18 am »
Attached a debuginfo from when it's broken.
« Reply #6 on: January 27, 2010, 12:31:00 pm »
How are you using an ulx command when ulx is broken?
« Reply #7 on: January 27, 2010, 03:11:02 pm »
Your users.txt seems to be corrupt, or ULib's reading of it.
ULX 3.4 has known issues with working with players with slashes "\\" in thier names.
If you open your users.txt file and find any \\\\\\ in it... you'd need to delete that entire record, or replace that field with a proper non-slashed name.
Offline vader0146
« Reply #8 on: January 28, 2010, 03:00:28 am »
Ah, probably happened because I have an escaped name.  >:(
