Author Topic: Install and setup  (Read 16012 times)
Offline ven0m
Install and setup
« on: February 13, 2010, 01:33:46 am »
I need help. i downloaded the files and put them into the addons folder but it screws my server up and i cant get on it and when i do download the files do i have to edit any or move any besides the addons folder. Please help
Re: Install and setup
« Reply #1 on: February 13, 2010, 09:09:39 am »
Inside the addons/ulx folder, if you installed it correctly, is a ulx_readme.txt file.
I suggest you read it, it has your answers both about installation and a link for how to add access.
Also, we have a FAQ area of the forums that will answer your questions.
I've never seen ULX prevent someone from joining thier own server.
Not saying it's not possible, but I've never seen it and am doubtful it's any of our doing.
You've not given an error or more detail as to why... and therefore I can't go further.
Offline ven0m
« Reply #2 on: February 13, 2010, 09:21:46 am »
this is wahat is happening hen i start up the server http://www.youtube.com/watch?v=2wVktt8fZFM andwhen i try to join my server it says bad challange
« Reply #3 on: February 13, 2010, 09:32:20 am »
ULX reports Admin Console is repeatedly changing the map.
This is most likely somewhere in a cfg file.
Sounds/looks like a bad configuration.
What have you edited?
Offline ven0m
« Reply #4 on: February 13, 2010, 09:49:22 am »
the host name and the rcon pass word and i put a welcome message and the // Please, if you have any compassion at all, leave this one in.
ulx addAdvert "This server is running ULX Admin Mod version %ulx_version% by Team Ulysses -- ulyssesmod.net" 540 this is what my server.cfg file looks like
// Server.cfg Executes on maploads
// For Convars like sv_cheats 1 = on 0 = off
hostport 27015 //Port used for the Server
Hostname "Hazardous RP" // host name
rcon_password "password" // rcon password
sv_password "" //Server Password
//DarkRP
net_maxfilesize 50
sbox_noclip 0
sbox_plpldamage 1
sbox_godmode 0
ulx map RP_DownTown_V2 DarkRP
rp_showjob 1
rp_toolgun 1
rp_proppaying 1
rp_letters 1
rp_earthquakes 0
rp_maxcps 5
rp_drugpayamount 30
rp_maxdruglabs 4
rp_maxgangsters 5
rp_maxgundealers 2
rp_allowpdchief 1
rp_dm_autokick 0
sv_defaultgamemode "DarkRP"
sbox_noclip "0"
sbox_godmode "0"
sbox_plpldamage "0"
rp_toolgun "1"
//Voice Chat
sv_voiceenable 1 // Enable Voice
sv_alltalk 1 // Allow all the teams to talk to each other
// Lan
sv_lan 0 // Lol Lan
//Rates (Don't change unless you under stand these)
sv_maxcmdrate 33
sv_maxupdaterate 60
sv_maxrate 0
sv_minrate 2000
sv_minupdaterate 20
//Fall Damage, 1 for realistic, 0 for 10 hp
mp_falldamage 0
//How fast a Spray can be Sprayed, In seconds
decalfrequency 3
// LOGGING
sv_logbans 1
sv_stats 1
log 1 //Turn this off if you don't like the logging in the console (L <date> then some other stuff), logs are in garrysmod/logs
//Leave off unless you want them on. (Most things that crash servers are cheats.)
sv_cheats 0
//Downloading
sv_downloadurl "http://a4p.host-right.info/orangebox/garrysmod"
sv_allowdownload 1
sv_allowupload 1
net_maxfilesize 100 //Holy , a command no one ever uses
"sv_lan" "0"
"maxplayers" "12"
"sbox_allownpcs" "0"
"sbox_maxprops" "15"
"sbox_maxragdolls" "0"
"sbox_maxnpcs" "0"
"sbox_maxballoons" "0"
"sbox_maxeffects" "0"
"sbox_maxdynamite" "0"
"sbox_maxlamps" "0"
"sbox_maxthrusters" "5"
"sbox_maxwheels" "4"
"sbox_godmode" "0"
"sbox_plpldamage" "1"
"sbox_playergod" "0"
"sbox_noclip" "0"
"sbox_maxhoverballs" "0"
"sbox_maxvehicles" "2"
"sbox_maxbuttons" "5"
sv_region 0
sv_timeout 65
//File for Mapcycle if you need it
mapcyclefile mapcycle.txt
//If you want something to not be executed put it like this
//sv_cheats 1
//if you put the slashes infront of something everything to the right of them is not executed
//Make sure the Bans are loaded
exec banned_user.cfg
// This is what the players will see when they join, set it to "" to disable.
// You can use %host% and %curmap% in your text and have it automagically parsed for you
ulx welcomemessage "Welcome to Hazardous RP We're playing rp_DownTown_V2"
Offline ven0m
« Reply #5 on: February 13, 2010, 09:55:06 am »
oh and when i take th ulib file out of the addons folder it works
« Reply #6 on: February 13, 2010, 10:57:42 am »
Do you see the "ulx map RP_DownTown_V2 DarkRP" in your config? Take that out and it'll stop looping endlessly.
Offline ven0m
« Reply #7 on: February 13, 2010, 11:38:04 am »
thank you so much it worked but how do i make the map rp_downtown_v2 now
« Reply #8 on: February 13, 2010, 12:37:40 pm »
If you want to change to that map, just type "ulx map rp_downtown_v2" in your console. If you want to start on that map, add "+map rp_downtown_v2" to the shortcut you use to start srcds.
