Author Topic: [DEPRECATED] [ULX SVN/ULib SVN only] AntiPhysgun [DEPRECATED]  (Read 16399 times)
Offline RynO-SauruS
« on: February 19, 2010, 10:04:24 pm »
This addon is now deprecated and no longer needed, because Megiddo has manually added restrictions to ulx physgunplayer.
AntiPhysgun is an addon for ULX SVN that adds an access called "ulx physgunplayer_protect".
When added to a group or player, the player(s) can't be picked up by other players with "ulx physgunplayer".
Note: this can be overridden if the player trying to physgun has the "overcomeimmunity" access. Removed in version 1.1
By default, it adds the access to the superadmin group.
I made this because "ulx physgunplayer" doesn't work with the new command system yet.
This is most likely only temporary, as I've been told by Megiddo, but this is just a quick fix.
Usage (if you want to use it for groups other than superadmin):
Type in the console:
ulx groupallow <group> "ulx physgunplayer_protect"
And if you want to use it for specific players:
ulx userallow <player's name> "ulx physgunplayer_protect"
Installation:
Extract to addons.
UPDATE: AntiPhysgun SVN version 1.1
FIX: Fixed the error since Megiddo removed the ULib.ACCESS_IMMUNITY global variable. (It's no longer needed at all)
I remember getting an error with this lately when it was working fine before, so I'm assuming this was the problem. (This is untested, post here if you have problems)
I also removed the check for "overcomeimmunity", following the way Megiddo did to the official PlayerPhysgun. (overcomeimmunity is retired now)
Enjoy.
« Last Edit: October 25, 2010, 03:01:05 pm by RynO-SauruS »
YouTube music player by RynO-SauruS
Nice!
Offline RynO-SauruS
Thanks.
Offline Ploo
If you have staff that annoy you with their ability to pick you up with the physgun, maybe, they shouldn't be staff?
I tend to agree, but not everyone rules with as much of an iron fist as some others.
Offline vader0146
This is good, it seems like it will be useful to a lot of people.  ;D
But really, did you have to release a 6 line PhysgunPickup hook?
Offline RynO-SauruS
Why remove someone's admin completely for picking me up, instead of just removing their ability to do so in particular?
I don't think picking up a superadmin is really grounds for removing someone's admin rights completely.
A lot of people don't know how to write a simple script to fix this problem. Why not release it?
Offline RynO-SauruS
UPDATE: AntiPhysgun version 1.1
See bottom of first post for details.
You are correct that immunity and overcomeimmunity were removed, they weren't really intended to linger as long as they did... I just kept forgetting to remove them.
